![]() | Home > Maintenance & Modifications > adjusting steering lock stops |
You can just pull the wheel by hand. You don't have to have the engine running. I assume you have the font axle on both sides on axle stands.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
thanks roel. I didn't think you needed axle stands. I was just going to check as is. But from looking at your impressive site I'd guess you have just a little more expertise than me, my Workshop manual and my € 20 Lidl Socket set
I do it engine on and use a bungy cord on the steering wheel to hold it fully left / right. easy that way.
You shouldn't hold on full lock with engine running for more than 30 seconds.
noogles Member Since: 07 Feb 2011 Location: Brunei Posts: 34 ![]() ![]() |
why? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
Something along the lines of, on full lock, the PRV inside the box allows the oil to flow past the piston, back into the pump/reservoir, and it can overheat quickly. Or it could just be that the PAS boxes don't like it...oil seals etc? |
I thought while steering the su=ystem build pressure to move the wheels when steady there is less pressure build up or equal on both sides. If you steer to full lock the system stays presurized and that is not good.
You can also hear it let somebody else turn the steering wheel to full lock and keep force on it you can hear the pump working hard if the steeringwheel is let loose the noise is gone. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Put it on full lock then turn off the engine, you will still be able to move the wheel especially if the wheels are off the ground Original Member Pie n Pea Club.
110 HCPU Tipper |
