![]() | Home > Puma (Tdci) > Will not turn over |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3708 ![]() ![]() ![]() |
You have reconnected the battery?!
robrennie Member Since: 20 Mar 2018 Location: Somerset Posts: 28 ![]() ![]() ![]() |
😀 good thought - but never disconnected it.
All lights work - dash lights up like normal, indicators work - cannot find anything that doesn’t work - apart from not turning over 😀 |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3551 ![]() ![]() ![]() |
By ‘poverty spec’ you mean you have no immobilizer/ 10AS, right?
Possible you knocked one of the wires off the ignition switch? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
There is an after market immobiliser - not sure what 10AS is?
I guess it is possible to have knocked a wire off the ignition- I’ll see if there is a unique wire for starting and does that have a separate connector there Cheers |
Dinu- thank you - I had knocked the wire off the switch! I was looking for a clever thing related to immobiliser.... |
