![]() | Home > General & Technical (L663) > Another Non Fixable 110 (MHEV)? |
| Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753
IIRC the porous float was more an issue on the 4.2 S/C engine than it was on the TDv6 so you might have to go back a very long way to 2005/2006/2007 to find the TSB Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Not the one I was thinking about but:
LTB00243NAS1 16th November 2009 - 'Check Coolant Level' Message Displayed Click image to enlarge |
Seems that was down to something seem in earlier vehicles many, many times: "The specification is insufficient at ambient temperature for the coolant expansion tank coolant level sensor retainer tabs. Once the coolant expansion tank gets up to a normal operating temperature, the tank retainer tabs are relaxing the force on the sensor. Vibration and shock load from driving is causing the coolant level sensor to drop out of its location and displaying a low coolant level warning, although the expansion tank coolant is at the maximum level." And the official solution is still the same: "Locally source two cable ties with dimensions of 2.5mm x 100mm x 1mm" Click image to enlarge Click image to enlarge |
| DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837
So it’s the driver’s fault for driving the car and the fix bodge is a couple of cable ties?
Just sayin. |
| SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 |
^^^ standard.
| 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history) ![]() |
| carlmuck Member Since: 21 Jan 2021 Location: Maryland Posts: 6
My 2020 NAS P400 threw a CEL at 600 miles. P144B - Purge Vapor Restricted.
Was told by the service manager that the fix is to replace the Clean Air Duct. So they'll call in a couple of weeks when (if) the part comes in from the UK. He said there was a service bulletin on this, but I can't seem to find one referring to that DTC or about the EGR system. |
