Home > Maintenance & Modifications > Removing dinitrol to paint
Co1
I’ve got some rust showing though on the chassis. Nothing major but would like to address it. What is the best way to remove the dinitrol in the area so I can treat it, paint it and then put dinitrol back over the top?
Or, would just whacking some dinitrol over the top of the rust be enough?!
Post #883525 6th Feb 2021 9:25am
LR90XS2011
spray it or paint it with white spirits, wait about 90 seconds and wipe it off, repeat until removed DEFENDER 90 TDCI XS,
Post #883532 6th Feb 2021 10:13am
Sulisuli
Co1 may I ask how long ago your chassis was dinitrolled? Mine was done 3 years ago but needs a refresh I’m sure. Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #883571 6th Feb 2021 2:34pm
Fat Cog
Re: Removing dinitrol to paint
I use this stuff to clear off the old wax & then retreat as necessary...it works a treat.
https://www.screwfix.com/p/no-nonsense-hea...5ltr/88668 Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #883574 6th Feb 2021 3:00pm
Co1
Just over two years ago. There is nothing major, just a few rust spots showing through that I want to keep on top of. I’ll do it this summer and then probably the whole thing dinitrolled again next summer.
Post #883575 6th Feb 2021 3:00pm
cold
Would it make sense to wire brush it, treat the rust with something like Hydrate80 and then Dinitrol- thats what I was thinking for my chassis.
Post #883579 6th Feb 2021 3:16pm
Dinnu
I use white spirit to clean the waxes. Lots of rags required, but depending on area.
I use a product called HG Rust Remover to clean the rust. It is a bit slow working, but it removes the rust, not convert it. There are other rust removers, like DrX, that work faster but find them to be more chemically aggressive. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #883593 6th Feb 2021 4:27pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
This stuff is my go-to solution for removing bitumen based sealants including Dinitrol overspray as well as the sticky residue from most self-adhesive items. It is excellent stuff. However, for removing a thick layer of Dinitrol I'd probably gently warm it up with a heat gun and scrape most of the wax off first.
Post #883603 6th Feb 2021 5:29pm
Linds Hanson
I really wouldn't put wet waxes anywhere near a vehicle they just make a snotty mess and hold in moisture until eventually pealing off. Better to prep the surfaces properly, remove any bolt on parts and treat with a proper primer something like Buzzweld Rust Encapsulator and then Chassis in One on top. If you don't want the work of prepping another good product is Lanogaurd which will need reapplying every couple of years but is much more effective than wet waxes.
Post #883613 6th Feb 2021 5:58pm
