Home > Puma (Tdci) > Loss of drive... Output shaft gone (i think) |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 |
Presumably you have checked the transfer box is properly engaged?
5th Feb 2021 8:38pm |
conora Member Since: 19 Jan 2018 Location: hertfordshire Posts: 25 |
yeah i check the transfer box, put it into high and low but nothing changed.
5th Feb 2021 8:50pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1728 |
And diff lock to rule out a diff/drive shaft / flange?
Keith |
5th Feb 2021 9:08pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5422 |
Where in Hertfordshire are you?
5th Feb 2021 9:37pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3614 |
shouldnt cost too much, but upgrade to Ashcroft or LOF if you are keeping it DEFENDER 90 TDCI XS,
based in Bushey mate!
5th Feb 2021 9:57pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3753 |
Yes, definitely output shaft. Happened to us several years ago.
Was driving along, then heard a sort of click/clunk, then shortly after lost all drive. Only issue you won't have is that it happened in Aussie in 35C+ heat, & it took around 4 hours with us sitting on the side of the road, very hot, waiting for a tilt tray! Pickles. |
5th Feb 2021 10:35pm |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 |
Certainly sounds like an output shaft failure as this is what happened to mine but make sure the hi-lo lever hasn’t slipped into neutral 1st.
5th Feb 2021 10:38pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 906 |
Well providing it isn't a drive flange (does it move in difflock?) then yes sounds like the output shaft.
Then if it is then LOF are the people to sort you out Click image to enlarge Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
5th Feb 2021 10:40pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
Defiantly sounds to be the output shaft mate
Id reccomend the Ashcroft upgraded shaft kit there awesome We aren't to far from you just down the a10 from the M25 enfield turn off - do have recovery aswell if you don't have RAC or AA Give me a shout ill try squeeze you in somewhere in the next week if I can in-between jobs CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
5th Feb 2021 10:46pm |
ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 185 |
Sounds very familiar.
I’d also recommend an Ashcroft upgraded shaft kit as the way to go |
6th Feb 2021 2:45pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
Although so far I've been lucky with mine, I do wonder, if misalignment is the reason for these failures, whether the LOF one piece shaft is likely to move the premature failure to a bearing instead.
6th Feb 2021 3:15pm |
jmw Member Since: 03 Aug 2019 Location: Brighton Posts: 3 |
Mine went at around 40k miles. Fixed under used car warranty but I think it was around 4 hours labour. The Ashcroft part is around £350, think OEM was about £150. Whoever does it make sure they have experience as an O ring seal on mine leaked afterwards. That was another 4 hours to fix. I think the problem was thought to occur due to it being a dry coupling, hence the Ashcroft solution?
Ask to keep the parts that come off - the transfer shaft makes a good doorstop and the coupling a tea light holder! On mine you could clearly see where the teeth had worn/shredded. Good luck. |
6th Feb 2021 4:12pm |
