![]() | Home > Maintenance & Modifications > Neoprene window block seals? |
jcw Member Since: 11 Sep 2016 Location: Gloucestershire Posts: 171 ![]() ![]() ![]() |
I’ve cut the 4 seals from 2mm rubber sheet using the card seals as a template, worked perfectly.
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3772 ![]() ![]() ![]() |
Thanks. I’ve got some 2mm rubber sheet as well so will give that a shot.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2516 ![]() ![]() |
EPDM flat roofing rubber offcuts work a treat. If you are after some just ask at your local roofing or building supplies.
I've also used rubber sheet to make gaskets. I used 1mm thick though as I'd tried 2mm on my previous 90 and whilst they worked, they did bulge out around the edges quite a bit.
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
I used 1mm rubber sheet. Rgds. Chris |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 170 ![]() ![]() ![]() |
Got any left over? Mine is collecting water now - it must be the only thing on it I haven't covered in silicone.
Think so pal - will give you some next time we catch up. Rgds. Chris |
Turns out the seals were fine. The idiot that installed the blocks forgot to tighten up the top bolt...
