![]() | Home > Technical > Door Lock Button |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
you need a thin wide tool which is, if possible, as wide as the bottom edge of the lock surround. You need to insert the tool at the bottom of the surround (between the surround and door card) and give it a sharp tap upwards. You might still end up breaking the bit that screws onto the door behind though as the cheap aftermarket ones tend to be more brittle, especially in the cold temperatures at this time of year.
Hope that helps, Steve 02' 110 TD5 Double Cab Rebuild Thread |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
try using a small piece of wood at the bottom of the slider and tap the wood gently upwards with a small hammer, Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
90roy Member Since: 21 Jun 2016 Location: Middlesbrough Posts: 130 ![]() ![]() |
Brilliant, thanks guys.
I'll give that a go. You're right about the aftermarket ones being brittle, I may try to locate some genuine Landrover ones and see if they fare better. 300tdi 90 1996. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3547 ![]() ![]() ![]() |
They slide vertically up. They can be hard sometimes to push up, but doable.
When re fitting you need to be careful that the back side of it slots in, as well as the 2 little pins that clip at the bottom. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Just use a small piece of wood under the slider and tap the wood with a small hammer or similar until it slides up. Jeff
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2321 ![]() ![]() |
This write up may help http://blog.discoverthat.co.uk/2018/06/def...moval.html
DOOR CARD FIR TREE FASTENER RECEIVER (THE PART THAT BREAKS IN THE DOOR CARD)SUITABLE FOR EZM500050 NEEDS TO BE BONDED IN
