![]() | Home > My New Defender (L663) > First decent motorway run today... |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1132 ![]() ![]() |
Had to go on an essential journey today. 70 mile round trip. Mainly motorway.
Active cruise is very good, once I was used to it. I found it best to keep the distance setting on 2 bars. It’s important you don’t hold the decrease distance button too long or it will switch off the active bit of the cruise control. I didn’t realise until the lorry in front got too close for comfort and I had to brake! So, adjust the distance by dabbing the button. If the active cruise slows you down because there is traffic in front, be ready for a rapid burst of acceleration when you change lane or the traffic clears. It’s a bit abrupt to be honest. Lane keep assist, I like it. There were no unwanted intrusions and I like the closing traffic warning, which once did flash a collision warning on the dash as I went through some roadworks and a car was close next to me. Very comfortable drive, and averaged 30.5mpg over the 70 mile trip. That was on the dash, so not sure how accurate it will be. Not bad if it is accurate, 300D engine. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 ![]() ![]() |
Not bad at all, on the weekend i did 185KM each way and was able to give the P400 a good run, it was returning 10.1l/100 KM's or 27.96 MPG in UK MPG terms. The trip stated average speed was 68KPH, however on the long highway stretches the average was "around 110 KPH" ![]() petrol receipts and they are close enough, within a 0.1/ 0.2 litres per 100 KM from what i can work out. ![]() Click image to enlarge yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
C&M Member Since: 28 Aug 2020 Location: Hampshire Posts: 185 ![]() ![]() |
this is the fault of most of them though isnt it? I had the same on a Mitz PHEV some years ago. Defender D250 HSE Dender 110 XS - sadly gone VW Polo VW Caravelle - Gen 6 |
No idea ~I've only driven versions of the RRS with it. Don't know anything about the workings of the system to understand why that should be deemed a "feature" rather than a fault.
It’s the first car I’ve had with acc. It’s not a fault as much as a design feature. It accelerates quicker than I would if I were in control. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Almost everyone commenting on it, in various forums, makes the same point about it being too rapid/not optimum. For me the question I've never seen answered is why it does, and why it can't be changed or best of all made variable so the owner can dial in what they want.
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
That's always seemed to be an issue with ordinary cruise control, too. Cancel to slow down and then press the resume button and it takes off like a stabbed rat. That's certainly been my experience in other Land Rovers (D2 - 4, FL2) but also in other makes. Darren
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Surely all it needs is a line of coding that basically interrogates the current speed and set speed and if it more than Xmph then restrict the speed advance to make them equal to Y - basically an acceleration controller.
All the ships I sailed in in the last 20+ years would only speed up on a load up program to avoid overloading the main engine - on my last ship the speed up (and slow down!) was 1rpm a minute from 57revs up to 85revs and then from 85 rpm up to 102rpm (flat out) took 1 rpm up and down 3 minutes but that could vary depending on the load on the engine. Even then it could take even longer because of the depth of water being shallow or strong adverse winds/currents that add external load considerations. OK that’s a bit slow for a car but we have the tech to do it! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 ![]() |
Me too - worst was a rental car I had in the USA many years ago - pressed Resume after a toll plaza stop and the car went absolutely berzerk!!! ![]() ![]() ![]() ![]() |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3495 ![]() ![]() ![]() |
Wife’s Skoda just the same 1951 80" S1 2.0
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 ![]() ![]() |
Will try it on my Karoq, don’t think I’ve done that yet. If I ever get legally back on a road where I can use CC.
stinus Member Since: 12 Jul 2020 Location: Kapellen Posts: 12 ![]() ![]() ![]() |
Sorry to go off topic, but what kind of ships do you work on, Tim? From what i understand they have big 2 stroke engines ![]() |
![]() Looking on Google maps at your location you will be used to seeing some of them on the River Schelde - we used to berth on the riverside terminal near Zandvleit Locks or over the river at Degeuren Dock. I worked for Maersk Line as Master from 2006 to retirement - before that for P&O Containers and P&O Nedlloyd Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
