Home > Maintenance & Modifications > Ignition feed under the bonnet - Lazer RS4’s
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
All,
Installing Lazer RS4’s.... into a D44 bumper, replacing the twisted drl bumper, looking for a ignition feed to tap into under the bonnet, I know the ignition feed is white and green wire, but does anyone know where I can tap into that into the loom.
Next question, does anyone know if the DRL’s in the Lazers dim when the side lights are turned on, or do they go off.
I’ve tapped into a existing live feed that the old Twisted’s were connected too to test things out.... but the twisted were a voltage controlled unit, which I don’t think the Lasers have...
Thoughts from those that went down this route..
Mark
P.S Twisted DRL bumper, with DRL’s and controller, for sale....
Post #881762 29th Jan 2021 5:18pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Buy a controller such as the powerful uk version, and just wire to the alternator, side lights indicators etc as required.
Post #881796 29th Jan 2021 7:45pm
Likeomg
lazers dim, i have a rs8 on the a bar.
for feed I just ran a wire from back of headunit.
Post #881841 29th Jan 2021 9:51pm
2010Blackdefender90
Thanks, I thought they dimmed, Will run an ignition feed from my Redvision and trigger them that way.
Post #881895 30th Jan 2021 10:12am
