Home > Puma (Tdci) > Starting problems, again....
Grenadier
Crikey, this is becoming a chore. This time I turn the ignition key and the Christmas lights come on, then turn to ignite and everything cuts out. Nothing mechanical turns over, so clearly electrical. Battery is 100%, all lights and switches work, radio etc. Is this the blasted switch or a dodgy wire? I noticed a brief problem with the off side headlight not working, then a shake of the loom and the light starts working again. Anyway, any thoughts on the craziness below? I have a new ignition switch (yet to be fitted) but wondering if the loom is the problem? Loose connection? Etc etc etc....
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #881326 27th Jan 2021 4:31pm
ickle
I'd start with the easiest / most obvious.
Battery earth clean and tight - try it
Jump lead battery to block - try it
fit switch (even just leave hanging under dash) - try it
main relay - try it
Obviously only change one thing before you try to start it again.
Mine did weird things when the brushes in the back of the starter were well worn and breaking up.
HTH Keith
Post #881388 27th Jan 2021 8:20pm
Check that the main and starter relays under the o/s front seat are really tight in their sockets. A poor or loose connection on any pin on either relay can cause these symptoms.
Post #881427 27th Jan 2021 9:11pm
Grenadier
Thank you both, will get on it this morning. Ickle, what do you mean by ‘Jump lead battery to block it’? Monsieur Le Grenadier
Post #881488 28th Jan 2021 8:08am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
He prob means take a jump lead connect the negative direct to the engine block to ensure you have a good earth incase the grounds on the block are broke Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #881490 28th Jan 2021 8:32am
Grenadier
Got it. Ta. Monsieur Le Grenadier
Post #881493 28th Jan 2021 8:33am
Dinnu
I hear a zapping sound. Is that a relay coming on/off/on rapidly?
The way the dash lights dim before going off seem like there is a high current draw through high resistance, like a dodgy earth.
Is there any clicking sound from the starter indicating that it starts to draw the high currents? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #881494 28th Jan 2021 8:38am
Grenadier
Will pop up and have a look again, once I’ve had my Wetabix Thumbs Up Monsieur Le Grenadier
Post #881495 28th Jan 2021 8:43am
