Home > My Defender > Grafty's Td5 90
Page 122 of 124 <123 ... 121 122123124>
bankz5152
Laughing thats why ive put off respraying mine! Paint would just get ruined. That said after a real proper clean and polish it does come up well!
Post #881295 27th Jan 2021 1:48pm
kenzle8a
The paint on mine will remain as is considering the horse uses it as an itching post sometimes...
Post #881303 27th Jan 2021 2:13pm
grafty99
If our horse did that to my 90 it would be turned into glue quicker quicker than you could say pritt Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #881351 27th Jan 2021 6:33pm
kenzle8a
Shes also tried to chew the steering wheel a few times... Part of being an appy I think, mostly shes 500kg of thug.
Post #881357 27th Jan 2021 6:45pm
grafty99
Luckily ours can't access where the vehicles are parked. Although she has bolted a gate twice before so perhaps she's trying Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #881363 27th Jan 2021 7:05pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
grafty99 wrote:
I think so, yes Thumbs Up
It's been a bit of a slow weekend so I've been playing around trying out different mounting locations for the clock in my defender. Since fitting the rev counter it's been displaced and I miss it. After trying different ideas I settled on a location between the sunvisors. Just waiting for the 3D printer to finish but this is roughly what it will look like - Install pictures to follow Thumbs Up
is it cheeky if I ask for an STL of that? lol
I fancy making one from Aluminium Grafty
Post #908433 18th Jun 2021 2:01pm
grafty99
PM inbound. 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #910693 4th Jul 2021 10:45am
atakanmerdin
Kenya
Infodash
HI grafty! Hoping to get a little more info on the td5 info dash. are you running it wired or over Bluetooth?
Thanks!
Post #922651 24th Sep 2021 4:57pm
grafty99
Re: Infodash
Thanks!
When using it I run it wired via a USB adapter to my phone Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #924948 8th Oct 2021 8:15am
Simboii
Wales 2006 Defender 90 Td5 HT Keswick Green
Have you any more info/pics of the intake setup your running from the wing to he airbox??
Interested to upgrade mine to a simular setup!!
Post #934367 20th Dec 2021 1:12pm
grafty99
It's a kit available from IRB Developments, it's an adapter that replaces the factory elbow out of the Airbox, a 4 inch pipe then an adapter on the wing - you also remove the water separator in the Airbox.
Here are some pictures Thumbs Up
1990 Vogue SE
Post #934558 21st Dec 2021 5:46pm
Simboii
Thats great, would be something if be very interested in getting!
Best to contact them regarding this setup then! Is there a big difference running this setup?
Post #934594 21st Dec 2021 9:52pm
jimbo55
Isn’t bad for a design I came up with on my lunch break from work (although Ian has changed a couple of bits), Nice to see Ian had some made over a year after I gave him the models
Grafty, how have you doubted the pipe under the engine cover? Mine goes over the top of the cover and never been too happy with it
Post #934595 21st Dec 2021 9:58pm
geobloke
It is a super mod for a TD5. I got impatient for Ian to get the kit together so made my own. The increase in diameter makes a huge difference when a RAI is added on to the intake length. Miffy breathes beautifully. If you get rid of the air boxes impeller then I highly recommend not fitting a forward facing scoop, but something like the Mantec mushroom style tops or Donaldson style bowl tops. With the scoop in heavy rain your air filter can get a little damp...
Post #934643 22nd Dec 2021 11:29am
grafty99
It does fit underneath, it's tricky to route it but it will go, you have to push the coolant pipe junction to the header tank down but with some persuasion it all fits. It's then cable tied up out of the way of the steering column. I don't think it would work with the double servo on ABS equipped defenders though? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #934655 22nd Dec 2021 12:22pm
