Home > Off Topic > Gravel driveway maintenance
Page 2 of 2 <12
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
+1 for the membrane.
I excavated down around 300mm then laid the membrane, followed by the MOT Type 1, rolled with a 5 tonne roller and laid the 20mm split flint gravel to a depth of around 50mm. You don't want too much otherwise you'll constantly be raking out ruts.
I also excavated for curbs and concreted these in to a depth of around 300mm.
Did mine around 15 years ago and still looking good. I do have to rake it level occassionally if I want to keep it looking nice. Plus a few applications of weedkiller during spring and summer to keep the weeks down. I only apply weedkiller to some areas of the drive as I have overhanging trees. Generally speaking the membrane keeps it stable and is not designed to suppress weeds at that depth.
Post #881301 27th Jan 2021 1:58pm
Since Paraquat was outlawed, Glyphosate is probably the best. It's not a good idea to use diesel since you will probably end up with a substantial fine (or even a free holiday on a small room) when someone reports you, plus your drive will stink (and so will your house after a while).
As noted above, get agricultural/industrial strength Glyphosate and use carefully, it is still quite nasty stuff.
Post #881304 27th Jan 2021 2:15pm
donmacn
There's not much chance of my using diesel - red or otherwise!
Just over the garden fence, between us and the forest, is an open drainage ditch/stream and quite apart from a personal conviction to do no more environmental damage than I can help, I've no interest in SEPA inspectors tracing a pollution incident back upstream to our driveway!
I like the idea of a 'proper' base and membrane job - but I like the idea of the finished job much more than I do the thought of the work and upheaval to get there. I'll consider it a bit further, but more likely is the weedkiller and fresh gravel approach. I'll see if the local farmer's supply place - a branch of Harbro - will stock the Glyphosate. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #881317 27th Jan 2021 3:03pm
Silver Back
Hope you get it sorted.
Here's the weedkiller I have used. Good stuff, but as others have said, use with care.
https://www.ebay.co.uk/itm/5L-GALLUP-XL-SU...%3A2334524
Post #881323 27th Jan 2021 4:11pm
donmacn
^^^ Thumbs Up Donald
in the past..
Post #881366 27th Jan 2021 7:19pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
For weedkiller, Gallup Hi-Activ is pretty lethal, it is about the highest glysophate content you can get but it will leave a slight orange stain to things like light coloured paving slabs if you mix it too strong/depending where you apply it. As others have said however, do not use on a windy day or contaminate other areas with your shoes etc, not much will grow there for 6 months + 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #881384 27th Jan 2021 8:10pm
htb2
Wales
6 mths without weeds, I dont think so its not a residual herbicide. I do a lot of weed control for utility sites. 1st visit April/May overall spray, 2nd in July spot spray and 3rd spot spray Sept/ Oct and thats in Scotland.
Post #881396 27th Jan 2021 8:32pm
JOW240725
Haha I learnt the hard way with the footprints, was being so careful too! Rolling with laughter
As for drive, as the song goes... it's all about the base! If it was a new driveway, excavate down to sub soil, compact, terram, hardcore, top lay 50mm. We did our drive like this with just planings on top, 18 years ago and still looks good. Just spray weeds 2 or 3 times a year.
Helps if you can get water away, if anything sits wet/boggy it will deteriorate.
However, as your drive is already there, just degrade and new top layer. My parents tar and chipping there driveway, gives a lovely finish but does need redoing every 5-8 years. James
Instagram @suffolk_rovers
Post #881444 27th Jan 2021 9:59pm
Chopperone
I use Round Up a fair bit.
At my supplier it is called Buggy.
When you apply it l always put about an egg cup full of washing up liquid in 50 Ltrs when spraying & it acts as a surfactant and makes it work much better.
Guy May your life be like toilet paper ; long & useful.
Post #884077 9th Feb 2021 8:44am
jst
https://www.progreen.co.uk/weed-control/to...nity-label
I use this and buy from them regularly. Does my driveway and anything around the house plus the margins on the off road site. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #884279 9th Feb 2021 10:29pm
Page 2 of 2 <12
