![]() | Home > My Defender > Fuji 110 LS3 build |
Stebo Member Since: 04 Oct 2019 Location: Northern Ireland Posts: 34 ![]() ![]() ![]() |
Coming together well. That's a class vid from Ged too
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2946 ![]() ![]() |
Thanks ^.
I have Laser Triple R's on the transit and the output from them is impressive so I knew I would miss the ST4's in the grille i recently sold. The equivalent linear unit to the transit lights are the Linear 12 15" so I am adding 2 of them to the rack. https://www.lazerlamps.com/linear-12.html ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 524 ![]() ![]() |
There is no difference in light output/beam with the ST4s mounted behind a mesh grille and it makes them a bit more stealth
Got on to the new lights this evening.
![]() Click image to enlarge Mounted them first using the top fix brackets with SS fixings sunk into the T channel at each side. ![]() Click image to enlarge Then remove the front cross member from the rack and drill 2 holes. ![]() Click image to enlarge Feed the loom thru the cross member ![]() Click image to enlarge And then a single connector attached in behind the passenger clamp. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 ![]() |
I've just sat and read this entire thread and all I can say about it is that its been absolutely awesome.
![]() That V8 sounds gorgeous and I bet you're going to have some fun at the traffic light grands prix. ![]() ![]() ![]() ![]() ![]() ![]() |
Went for a drive today. Better brakes on my granny’s bike so must get them firmed up in the morning but apart from that all seems well. Going to bring her home tomorrow. Andy
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3712 ![]() ![]() ![]() |
Managed to get hold of a 14” version. It helps just living down the road from twisted! Does the front boss just pull off or is there a knack to it? I don’t want to end up chewing up one of the edges. |
Have to say my favourite part of the drive was the new steering wheel, better that the startech.
Yes a wee spray of oil onto the splines, let it sit and a gentle tap should free it up. ![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Good to have it back home. Have the first 100 miles run in and so far so good. Brakes are getting better, slight rattle from exhaust on the mud flap bracket but i was expecting that. Need to adjust the gearbox cable to get tiptronic to engage.
I got the front cubby lid printed so I can now get them covered, although I might leave it a while in case I think of something else I might add... Also fitted the rear seat heater switches, same place as before. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7926 ![]() ![]() ![]() |
Seriously envious, looks amazing!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Andy what’s your thoughts on the new Lazer linear lamps? 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
Not actually hooked them up yet. I think I am going to make a nice wee fuse board under the rear cubby, keep all the LS loom, modules etc in the main battery box and then the other bits I add all back in the rear. Andy
Will be interested to know your thoughts, they look the usual high quality from Lazer. 2015 HT XS 90
Very subtle for the rear heater switches. Nice work 👍
