Home > Technical > Ashcroft Transmissions - Half Shaft / Flange Failure
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I've got Ashcroft half shafts and drive flanges fitted to the 110 and at the weekend, following a loud bang, a rear drive flange gave way, sheering all of the splines where it connects to the half shaft and unfortunately damaging the splines on the half shaft also.
Having pulled it all apart, there was plenty of grease inside the flange so it wasn't a lubrication issue but it's clearly been wearing away for some time judging by the wear marks on the half shaft. I've had the vehicle for 5 years or so and these were fitted by a previous owner so obviously not a warranty claim to Ashcrofts but has anyone experienced a similar issue before?
With regards to replacements, I don't really need HD Aschroft units if standard ones are fine, does anyone have any recommendations on specific brands to either avoid or choose? Is it also a sensible time to convert to one-piece shafts /flanges and avoid another wear point in the transmission?
 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #880765 25th Jan 2021 1:16pm
JOW240725
IRB do a one piece rear halfshaft, i believe others out there too possible even BritPart. No experience of them but had them on my list should it be an issue. James
Instagram @suffolk_rovers
Post #880769 25th Jan 2021 1:36pm
Dinnu
Is it an early or a later 110 axle.
Just recently there was a topic on axle straightness. If not very straight it can chew up splines. Note that JLR di not specify very tight tolerances, such as camber, even in a rear axle. Hope this is not the case. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #880777 25th Jan 2021 2:22pm
Harry.O
Thanks JOW, I'll pop Ian at IRB a message and see what he has to say Thumbs Up
Hi Dinnu, it's a 2005 TD5 which I think uses the p38 short-nose type of diff. It doesn't appear to be a dodgy casing though, I've never noticed any unusual tyre wear in the 5+ years I've had the vehicle. 2005 Td5 110 Hardtop
Post #880780 25th Jan 2021 2:36pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
My school of thought on half shafts and drive flanges has always been to run standard flanges and upgrade from the inside out on the basis that you'll most likely suffer breakages at the weakest point in your driveline. Running HD flanges and shafts could effectively render the diff/prop your weak point if they're not upgraded. Conversely, running standard flanges should help to protect your diff/shafts/prop as your flanges will likely go pop first. They're also an easy swap in the field and are only a fiver each. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #880788 25th Jan 2021 3:14pm
If you do want one piece shafts (a big improvement, in my opinion) then those from a later Disco 1 will fit. Alternatively, many people have fitted those from Britpart and there haven't been any horror stories yet. Darren
Post #880795 25th Jan 2021 3:41pm
htb2
Wales
Disco 1 shafts in mine
Post #880842 25th Jan 2021 7:20pm
LR90XS2011
I have a set of 300 tdi one piece shafts that I recently paid a forum member £40 for if you want them for the same money I am near the NEC, I'm not using them as they are exactly the same as the disco 300 tdi ones I already have, I also have the original low mileage 2 part ones that I am not using.
PM me if interested DEFENDER 90 TDCI XS,
Post #880847 25th Jan 2021 7:31pm
Co1
Britpart on mine. No issues with them, only good news 2 years down the line.
Post #880848 25th Jan 2021 7:32pm
Zed
Fairly certain both IRB and LOF use the Britpart version. WARNING.
Post #880849 25th Jan 2021 7:32pm
jimbo55
The only difference between an IRB or LOF ones and britpart is the coating. (Britpart come untreated), 300tdi ones fit but are not as strong as the later td5 and puma shafts.
Depending on your usage, Ashcroft HD shafts May be a waste of money.
I went with the cheapskate option of welding up the standard flanges before they failed but would have gone for the IRB ones if they were available at the time.
Post #880866 25th Jan 2021 9:21pm
Mo Murphy
I use old disco one piece half shafts with the rear locker without problem or breakage.
If you're only using yours on the road then all heavy duty does is give you bragging rights.
50 Shades of Pennine Grey
Post #880872 25th Jan 2021 10:03pm
90GTR
 2016 Defender 90 V8 Petrol Works V8 Auto Santorini Black
how timely... and hoping I can jump on the back of this with some questions for a friend. They're thinking of upgrading to 1 piece half shafts after suspected deterioration of the original ones.
They're getting a bit of a thud on take-up after 10+mph and is unsure if it could be worn bushes or half shafts. He had the flange off and thought play was v. minimal for the flange and shaft. Teeth seemed fine..
OP were you getting any symptoms prior (or to the others is a thud on take up indicative of half shaft wear)?
Post #880884 25th Jan 2021 10:41pm
jst
90GTR, the 'thump on' does it come with a change of direction too each time (ie fwd to reverse?) sounds like bush to me rather than shafts/DMs Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #880980 26th Jan 2021 11:18am
jst
Ref the grease/wear and Ashcrofts, it advised on Ashcroft site to remove the inner hub seal to allow oil to lubricate the splines. Wonder if that was done?
The halfshafts and drive members we provide are warranted against BREAKAGE, not against wear caused by 'fretting corrosion' of the spline/drive member interface. This 'fretting corrosion' is a direct result of lack of lubrication, a design fault, and is common on grease filled hubs. We therefore recommend removing the half shaft seal to allow oil to migrate along the half shaft to keep the spline lubricated.
Para 4: https://www.ashcroft-transmissions.co.uk/h...s.html[/b] Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #880985 26th Jan 2021 11:37am
