Home > Technical > Reverting to old type top swivel bearing
Oldowner
Any downsides to ditching the later upper swivel pin setup on a non-ABS Puma and reverting to the old top pin and separate 606666 bearing? I would rather the larger bearing area of the earlier setup and be able to fit quality Koyo / Timken etc bearings rather than rely on the later unknown one piece combined pin and bearing race with unbranded bearing.
I have never liked the later TAR100040 top one piece swivel pin and bearing arrangement, this seems to have come about due to rationalising the axles when ABS was fitted to the Defender and they had to find a way of stuffing the ABS sensor into the swivel without using the earlier Disco Railko bush.
Post #880248 23rd Jan 2021 7:59am
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
I'm doing exactly this on my 127, the Timken bearings aren't cheap (about £18 each) but like you it gives me peace of mind to know I have good quality bearings top and bottom. You could argue that the lower bearing takes most of the forces and the top really only keeps the housing straight/steady and thus a railko is sufficient but as I'm not running ABS I saw no point of going with the bush setup.
If my memory serves me correctly, you may need new swivel balls as the railko bushes are a larger diameter than the outer bearing races. Something to consider. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #880280 23rd Jan 2021 10:24am
Oldowner
I am reverting from the Puma taper bearings back to the earlier taper bearings, so the swivel balls stay the same.
Post #880288 23rd Jan 2021 10:53am
Shroppy
Ah, I misinterpreted that. In which case, I'd go for it. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #880289 23rd Jan 2021 10:57am
There are no downsides at all that I am aware of. In effect all you are doing is reversing a cost-cutting economy that LR introduced and reverting to a better-engineered solution.
Post #880301 23rd Jan 2021 12:08pm
