Home > For Sale & Wanted > [Wanted] JEI100030 TD5 fuel pick up pipe and oneway valve
benspray
United Kingdom 2006 Defender 130 Td5 HCPU Chawton White
Hi All
I have a Thermo top C that I removed from my 101 when sold, I'm looking to fit this to my replacement vehicle (2006MY TD5 130) and ideally want to fit as per the official kit (ish)
Looks like JEI100030 is the fuel pipe / stand pipe that goes into the TD5 fuel pump but I can't find it available anywhere, also I'd need the one way valve that goes into the header tank return/breather hose (the top one)
I could use one of those pickups that cuts into the fuel filler pipe but not keen really...
Anyone have one kicking about Smile ?
Thanks all
Post #879610 19th Jan 2021 9:52pm
Matt110
Have to say I've just fitted the fuel filler pipe and it's brilliant. So simple to fit, no tank dropping, easy access for service if it ever had a problem. I'm well chuffed.
Sorry I know that doesn't help but just in case you can't find one.... A vote that says the inevitable alternative is good! Very Happy
Post #879629 19th Jan 2021 11:24pm
benspray
Cheers may be the best/only way Wink see if anyone has anything though if not will go with that.
Post #879843 21st Jan 2021 12:22am
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
The Fuel filler pipe was the method Land Rover SVO always used for their installations. Richard
Either a 90, 110 or 130.
Discovery 5
Post #879929 21st Jan 2021 2:38pm
