Home > In Car Electronics > dcpu rear speakers
Christophe
Belgium 2004 Defender 110 Td5 DCPU Java Black
dcpu rear speakers
Looking to add some speakers to the rear of my dcpu. What are the mounting options? Are there pre-made brackets available for this? Anyone done a similar job and willing to show their fitment? 04' 110 TD5 Double Cab
10' 90 2.4tdci Station Wagon
Post #879525 19th Jan 2021 1:01pm
Matt110
JOE_130 and I made up some speaker boxes for the rear of his DC. Couldn't find anything to buy. We just cut out marine ply in the right shape such that the speakers would fit behind the seats (which aren't fitted at the moment).
Think it depends what speakers you want to fit. We fitted 6.5" components. They sound good without a sub although he also has a 12" sub box we made to fit in the middle, all along the back above the rear "shelf" that's created when you take the seats out behind the seat box.
Photos would be good but haven't got any at the minute.
Are you trying to fit them up high or down low?
Post #879527 19th Jan 2021 1:08pm
Christophe
Considering the focal pc165's and a woofer to mount behind the seats. 04' 110 TD5 Double Cab
Post #879528 19th Jan 2021 1:25pm
Matt110
Should work OK as they're the same size as ours.
Make up a triangular flat faced box to sit behind the seat pushed into each corner on the ledge behind the seats. Doubt a sub would fit behind there with seats still fitted, but we were considering making a second iteration that used the seat box as the sub volume so that might be an idea. No wasted space then.
Post #879549 19th Jan 2021 3:06pm
hank
Just a suggestion, fit the focal's in the front with a woofer under the rear seats and you may well find you don't need rear speakers too Thumbs Up
 > 110 XS Double Cab
Post #879569 19th Jan 2021 3:55pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Yep, done that - 6.5" Hertz speakers under the rear seats in custom boxes, and a 10" sub in custom enclosure - running of a 6ch amp under the drivers seat.
 110 Tdci Double Cab
Post #879731 20th Jan 2021 3:15pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Those speaker boxes look great! Do you happen to have plans or measurements for them?
Post #880044 22nd Jan 2021 12:28am
Grenadier
Like Hank, I’ve swapped the standard DC speakers with Focals and added the Focal ibus amp/sub under the rear seats. I’ve bought two more pairs of focal speakers and will (when I get my arrrrse into gear) fit the 10cm in the headlining above the b-pillar and the 13cm pair in the headlining in the rear corner about the corner windows, using spacers to add depth. They will then be wired into the head unit using the Focal 4.320 mini amp, which I shall fix under the dashboard cover over the passenger side handle. That provides a six-speaker, two-tweeter, one-sub (9-speaker), two amp set up, with 50% above head height, 50% at head height. I have soundproofed the whole cabin, including adding high density egg-box sheet behind the rear seats and a super thick sound blanket between the headlining and the roof. Thumbs Up
https://www.focal.com/en/car-audio/car-aud...pulse-4320 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #880053 22nd Jan 2021 8:32am
