Home > Tdi > Oil level rising...
shaggydog
Oil level rising...
Hi all,
well good news the alternator issues seem to have been sorted (for now)
However on doing my pre-start I found that the oil was up near the danger mark.
This is a bit of a shock as I had expected it to have dropped rather than raised having been stood.
Coolant is clear and no signs of snot on the dipstick or oil filler, coolant not over-pressurising so I'm fairly happy its not that.
However it does seem to be a bit down on power, was running a bit hot on test drive. The oil doesn't smell of diesel but its definitely not at the level I had previously run it at.
Part of me is tempted to drain out the excess and run it for a day see where it ends up though I have a horrible feeling that could do a lot of damage.
First thought is the lift pump leaking into the block and then sump, secondly the injectors.
Any tests or checks I can do before I start buying parts?
All the best Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #879200 17th Jan 2021 9:59pm
camelman
We had this on one of the Mountain Rescue TD5s. Was a cracked cylinder head and diesel leaking into the sump.
Post #879201 17th Jan 2021 10:01pm
shaggydog
Exactly, which makes me think injectors or lift pump as there is nowhere else it could come from! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #879204 17th Jan 2021 10:09pm
htb2
One thing you can check for diesel dilution. Dip dipstick put a drop of oil on some blotting paper. if only oil there you will have a full consistent circle. if diesel dilution in oil you will have a halo round the oil circle.
Post #879207 17th Jan 2021 10:24pm
camelman
we had a hairline crack in the head , enough to squirt diesel through under pressure Sad
Post #879209 17th Jan 2021 10:26pm
Retroanaconda
Diesel dilution on Tdis is not common like it is on Td5s.
I would change the oil and then monitor the level over a few hundred miles, see if it moves again.
Post #879211 17th Jan 2021 10:27pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
Check the length of the dipstick tube. It is a common problem on Defender 200 Tdi, that because the fitting isn't secure, the tube can slide down dipping the dipstick deeper into the oil.
It should be 283mm from the top of the nut to the top of the tube. Any shorter and it'll be reading high.
Post #879213 17th Jan 2021 10:36pm
shaggydog
Right, some quick tests done!
Dipstick measured the dipstick and its measuring 295mm from top of nut to top of tube which i have a dim and distant memory of doing this previously as it was loose and misreading.
Needed all my extensions and a crows foot but got it tight Thumbs Up
Oil drip test completed
1st drop from the dipstick as removed, then the second was it cleaned, re-inserted and then dripped.
I think it is showing no halo so the plot thickens? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #879230 17th Jan 2021 11:54pm
Mo Murphy
You've over filled it ?
Post #879301 18th Jan 2021 1:29pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Oil will float on water, now let's assume that the water and oil didn't mix.
Loosen the sump plug and let a little bit out.
It'll be a little messy but it will be another thing to tick off the list.
Post #879321 18th Jan 2021 3:21pm
Mo Murphy
Oil and water in an engine get well mixed and form an oily white emulsion which will be seen under the rocker cover through the oil filler.
Post #879325 18th Jan 2021 3:30pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Sounds like it’s Engine oil and filter change time..
Ensuring you refill with 6.85 litres regardless of the dipstick.
Post #879328 18th Jan 2021 3:48pm
jfh
Mo
Yes , I've seen it enough times, that's why I said assume. Nothing surprises me anymore.
Post #879330 18th Jan 2021 3:54pm
jfh
I approached it from the wrong side. The question should be: Are you losing water?
Post #879334 18th Jan 2021 4:13pm
shaggydog
Hi guys,
Just to update on this, no loss of coolant and no obvious routes of water ingress.
Will drain, refill then keep an eye on it.
Not the best time for this to happen as my other truck is going in for its MOT on Saturday Big Cry Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #880313 23rd Jan 2021 2:07pm
