![]() | Home > Wheels & Tyres > 285/75’s on 8x16 ET0’s - will I have a problem? |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
I ran that set up on the 110 with no problems.
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2355 ![]() ![]() ![]() |
No rubbing on mine 285/75/16 at ET0 with standard suspension. Moved to ET-30 and had minor scrub to the bottom rear corner of the front arch spats at full lock. > 110 XS Double Cab
A pic of them fitted.
m33ufo Member Since: 19 Jan 2008 Location: Cardiff Posts: 1154 ![]() ![]() |
Much appreciated gents
![]() Mark Last edited by m33ufo on 17th Jan 2021 7:27pm. Edited 1 time in total |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
The issue you might have is if its pushing the boundaries for being out the arch too far.
For reference I'm running 285/75/R16 on my own 90, but on a +10 offset rim, and its pretty close to being inline with the arch, maybe 2-3mm inside, using the BFG KM2 tyre. Maybe you'll get away with it depending on which tyre you select. 2005 Td5 90 XS 1989 V8 110 CSW |
My initial thought was STT Pro’s but haven’t purchased tyres yet so that’s not set in stone. 110 DCPU
Mark |
That looks spot on ![]() Mark |
Think I am pushing the boundaries but so far have got away with it ![]() ![]() Click image to enlarge > 110 XS Double Cab |
Is that with your ET -30’s? 110 DCPU
Mark |
Yeah. More like this at ET0
Awesome...that’ll do me 👍🏻 110 DCPU
Mark |
For reference, here is my 285/75/R16 on the original (possibly sagged) suspension, ET10:
![]() Click image to enlarge It didn't rub on road, but as I also wanted to go off-piste, I added a 2" lift, where there has been no rubbing even at under articulation (although its pretty tight at the back). ![]() Click image to enlarge 2005 Td5 90 XS 1989 V8 110 CSW |
Simboii Member Since: 09 Jun 2021 Location: Carmarthen Posts: 80 ![]() ![]() ![]() |
Did you get around to fitting 285’s! I’m thinking of getting a set but dont want the hasstle with rubbing!! |
Played it safe with 265 KW3’s in the end. 110 DCPU
Mark Last edited by m33ufo on 10th Jun 2021 9:55am. Edited 1 time in total |
