Home > In Car Electronics (L663) > Wireless CarPlay
Page 3 of 3 <123
GreenMonster
United States
I’ve been using the wireless gadget with my iPhone 12 for a few weeks and I’ll be putting it back up on eBay soon. I usually use tidal or Apple lossless files on my iPhone, and the degradation in sound quality going to wireless is significant. Also, the song showing on the screen is often out of sync, and the device will just pause for no reason. Just not worth the small improvement in convenience.
Post #879002 16th Jan 2021 11:52pm
W84IT
United States
What you're describing is a software issue. You just need to update the software on the wireless device that you have. The GoPlayAuto device that I use for wireless CarPlay has been great. I was having the same issues that you described until I contacted the manufacturer and they told me to update the software. Since then, it has been working fine and I can't tell any difference from the wired connection. Ray
2020.5 Defender 110 P400HSE
2016.5 Range Rover HSE
Post #879010 17th Jan 2021 3:11am
GreenMonster
United States
Thanks. I’ll give the update a shot. Doubt that will improve the audio quality, but I’ll see if it helps.
Post #879012 17th Jan 2021 5:11am
VinSuz
United States
So still no word on wireless CarPlay in an OTA update? 2020 Defender 110 P400 HSE Santorini Black/Ebony
2019 Jaguar I Pace HSE
2022 Chevy Bolt 2LT
Post #911539 9th Jul 2021 4:09am
J77
The Velar has just been updated for 2021 and will receive a SOTA update to support wireless CarPlay, I assume the update will filter through the LR range.
From LR media site.
Wireless Apple CarPlay® and Android Auto™ is intended to be released as part of a wireless software update on all Range Rover Velar models expected later this year, at which point the features will also be available via a SOTA update for all Pivi and Pivi Pro equipped Range Rover Velar models. 24MY 90 D250 HSE, Tasman Blue
Post #918064 20th Aug 2021 10:22pm
J77
Received wirless CarPlay as part of an update done at the dealers.
If you have it you should have “wirless” listed in the connectivity menu, make sure this is on. With the phone unplugged I pressed the voice command (long press), then went into Bluetooth settings on my phone and reconnected the phone. It then came up on the pivi screen, can’t remember the wording but press yes.
This was Apples instructions. 24MY 90 D250 HSE, Tasman Blue
Post #927483 28th Oct 2021 6:13am
Gareth
If you have wireless CP enabled, does it disable the wired CP?
I’m just thinking ahead, because I have put in a hardwired holder that charges my phone. I’d like to keep using it. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #927488 28th Oct 2021 6:46am
Brulz
Italy
Post #927502 28th Oct 2021 8:32am
J77
No idea, only played with it for a couple minutes before starting work. I imagine it won’t make any difference. 24MY 90 D250 HSE, Tasman Blue
Post #927542 28th Oct 2021 11:52am
mse
The disco got this today, software no was v3
Defender update the day before didn’t get it, I wonder if it’s behind Mike
Post #928310 2nd Nov 2021 11:38pm
J77
iOS 16 on its way, brings with it an updated CarPlay. Now works with interactive dash, apparently
Post #954784 7th Jun 2022 11:07am
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
The presentation looked slick and can see this being the "OS" fir an Apple Car (if it happens), but I doubt the hardware is there for it to be backward compatible with existing vehicles. https://instagram.com/bentheoandrews
Post #954807 7th Jun 2022 2:15pm
Page 3 of 3 <123
