Home > Maintenance & Modifications > Fitting Replacement Mud Flap Brackets
wynn153
Hello, Very Happy
I have bought some stainless steel mud flap brackets for puma 90 and am just looking for some advice about removing old brackets with rusted bolts, and for some tips about fitting new ones. What fixings do I use to attach the brackets? And what do I attach the mud flaps to the brackets with (with black heads so they bend in)?
Thanks for your help Thumbs Up
Post #878946 16th Jan 2021 8:42pm
Dinnu
All Front and rear brackets on 90s fit with rivnuts. The chances are that the rivnut would spin with the bolt. If that happens, on the front there is a chance that you grip it with a small mole grip plier. The rear on a 90 is harder to get to, so probably the only option is an angle grinder to the head of the bolt. Once the brackets are off, you can try to gring what remains of the bolt flush with the chassis, and then nock the rivnut in.
The rear on 110 are hanging differently, partly hanging to the body.
The way I mounted the mudflaps (the rubber part) to their brackets were by using stainless steel carriage bolts (slightly modified - I turned the square section beneath the head round, and turned the head smaller to be exact size of the original rivet). I think they were M5 but could have been M6, not sure anymore. Forgot the length.. but around 12mm. The original are aluminum rivets, and were unpainted. So I left mine unpainted too. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #878966 16th Jan 2021 9:21pm
wynn153
Thanks a lot for that. it is a 90. that is very helpful. Thumbs Up
Post #878989 16th Jan 2021 10:37pm
When I did my fronts (rears are different on a 110), I used some M6 stainless nuts and bolts. I also made some spacers from some offcuts of rubber matting to fit between the flaps and the brackets for each bolt position to create a gap. This is because I discovered a huge build up of crud between the two when I separated the originals.
There's a bit more detail here: https://www.defender2.net/forum/post728084.html#728084
As for black fixings, that's a matter of choice. As mentioned above, the originals are aluminium rivets so nothing particularly special and whatever you put there will be grit blasted in no time unless you also fit Gwyn Lewis guards. Darren
Post #878990 16th Jan 2021 10:49pm
lakelander
United Kingdom 2013 Defender 90 Puma 2.2 CSW Orkney Grey
Admit I'm being over the top on this one , but is it possible to get hold of stainless steel ( or galvanised ) rear brackets with the oe style raised profile section. All the Stainless ones I have seen are flat profile. I want SS but I want my vehicle to look as it did when new.
Fitted SS front brackets but no issue as oe are just flat. Used YRM which are great . Holes to attach flaps are square cut to fit the included coachbolts . Had the brackets powder coated locally.
Do all Defenders have these rear raised profile brackets or is it just Pumas? I notice Land Rover do a genuine part MUC3987 which is powder coated mild steel with a flat profile? Seems that the only source of the raised profile design is OE but these are mild steel and come with flaps attached.
Post #930665 22nd Nov 2021 12:22pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
sorry to jump on the thread, i'm going to be fitting mine to a new chassis and theres no holes. Would someone mind taking a pic of the locations to give me a datum point to fit them Very Happy Thanks
Post #930672 22nd Nov 2021 2:26pm
markb110
When I last refitted my rear mud flaps (90) I made a hole in them to match the drain hole in the cross member that the bracket covers over. Use a step drill bit.
I also added some self adhesive neoprene (eBay) to the bracket so that there is no metal to metal contact and take away a cap where crud can collect.
. Thumbs Up
Post #930683 22nd Nov 2021 4:12pm
lakelander
I guess you need a photo with the flaps removed? Just fitted mine , should have taken a shot . Hopefully somebody will have a truck with them removed. If not PM me and I'll sort something out - just getting a bit cold and damp !!
Post #930695 22nd Nov 2021 5:49pm
shanecl
I hear you about the cold and damp Rolling Eyes . I was born in the wrong country,
Photo of them on will do perfect. Just to see there they roughly line up on the crossmember and outrigger
Post #930814 23rd Nov 2021 2:20pm
lakelander
Ok will sort something out
Is it the fronts you want or tears as well
My fronts are new but rears pretty gunged and grotty ?
Post #930935 24th Nov 2021 10:14am
lakelander
Tears!!
Rears!
Who designed the autotext!
Post #930936 24th Nov 2021 10:15am
lakelander
You'll probably experience tears as well!!
Post #930937 24th Nov 2021 10:16am
Stacey007
I fitted new ones to my Defender front and back
Fitting the front brackets I had to drill the bolts out...
I had never heard of a nut riveter but it worked a treat just drill a new hole, insert these and it creates a threaded recess to attach a new bolt.
only bought a cheap one similar to this
https://whiterosetools.com/products/bluesp...MAQAvD_BwE
I still have the rear ones to do, I Have new stainless plinths so will attack them one day.
Post #930941 24th Nov 2021 10:42am
mikeh501
I found the originals on the rear eventually rot out or you end up running over them reversing off road. Its not a great design. I opted for this bracket which bolts to the rear crossmember which lifts the flap up and back. It also makes it very very easy to replace them as it doesnt rely on the rivnuts at all. I think they were from bear 4x4 or something like that, it was a while ago.
Post #930946 24th Nov 2021 11:06am
lakelander
Just wondered why you had to drill new holes. I drilled my fronts out and just put new rivnuts into the existing holes.
Post #930976 24th Nov 2021 1:47pm
