![]() | Home > Puma (Tdci) > oil on map sensor |
I don't think anything will burn off. You'll need to clean it or, at worst, replace it and see if that makes a difference. Darren
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
As above, clean it for now then look to replace it. They aren’t all the expensive. If you use the search function on here you’ll find more info. (Especially for a 2.4). ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Primaryroo Member Since: 15 Aug 2020 Location: kent Posts: 21 ![]() ![]() ![]() |
oh the reason for taking map out was for replacement....thats when i noticed. changed turbo actuator thingy and map as over pressure fault on engine when occasionally when lifting off throttle on motorway it would go into limpish mode reduced power.....everything else checked out ok series 2a 1966
defender 90 1991 discovery 3 2005 discovery 2 2003 defender puma 110 2008 defender puma ex scottish power 2.4 2011 |
