Home > General & Technical (L663) > Pre heat option..
Gareth
Pre heat option..
This morning is a cold one (for Manchester UK) about -3 with a thick freezing fog.
Had to go out early so hit the remote start on the App. (No preheat option on mine)
After 25 minutes it had defrosted the windscreen and rear screen, but not the side windows. I think it used the electric heaters to do this.
The interior was barely mild! The engine is obviously so efficient it doesn’t quickly heat up.
So, maybe ticking the times pre heat option with remote etc. is a good thing if your out regularly in sub zero. I had it on my D4 but hardly ever used it. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #878584 15th Jan 2021 11:06am
Tim in Scotland
Gareth - On the app you can set a desired temperature (just below the big start button) - tap on the temperature and a new window opens that you select the temperature you want on it). AFAIK mine has never reached the “desired’ temperature (and I don’t have the optional park heating ) but the side windows change from being frosted to being covered in condensation and the mirror heaters seem to have a small effect on the front side windows from radiated heat. Next time you run it have a look at the engine temperature display and you will find it’s halfway to “normal” on completing a remote start cycle. I think that’s why LR call it a remote start not a pre-heater. I usually gave hot air coming out of the dash vents within 2 miles of driving off - the heated seats and steering wheel help to warm you up until then too as you’ve probably found out now!
 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #878587 15th Jan 2021 11:19am
Gareth
Yes I spotted that and set it to 22. Soon warmed up once driven. The heated wheel gets really warm! 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #878597 15th Jan 2021 1:13pm
Tim in Scotland
Too warm, same with the seat heaters, although when I put my back out last August just going out and sitting in the car with the seat on No3 setting gave great back pain relief! I have read that the seats that are heated and cooled aren’t quite as warm as the non-cooled ones for some reason. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #878617 15th Jan 2021 3:19pm
Gareth
Yes I’d agree with that. My D4 seats certainly heated up quicker than the Defender. It still gets pretty warm and needs turning down though. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #878647 15th Jan 2021 5:56pm
J77
The new Defender seems a backwards step, I use the nice new app on the Velar but on my shiny new Defender that’s supposed to have 85 ECUs and the latest and greatest tech I will have to use the old app Confused 24MY 90 D250 HSE, Tasman Blue
Post #878690 15th Jan 2021 8:39pm
mse
I use the new app on all of ours, worked fine yesterday heating the car
Although realised the rear window was open 1mm since new Sad Mike
Post #878695 15th Jan 2021 9:32pm
AndrewS
What app are you using? This is what mine looks like when using the climate heat.
Hold the green button till it does its thing (about 5 seconds) then off it goes.
 130's have feeling's as well you know Smile
Post #878710 15th Jan 2021 10:05pm
Retroanaconda
New app works fine for me.
Post #878718 15th Jan 2021 10:32pm
J77
I use the same app as you for my Velar but Tim is running the old app, seems a few others are as well, as the new one wouldn’t connect during set up. 24MY 90 D250 HSE, Tasman Blue
Post #878724 15th Jan 2021 10:43pm
mse
Yes both work for me but I use the new one, runs a bit better Mike
Post #878733 15th Jan 2021 11:19pm
Tim in Scotland
New one refuses to recognise my user name/email/password - I spent a week with JLR iT trying to get the “new” one to work and when I tried the old one got logged on straight away. Gareth seems to have the same issue as do quite a few people on another forum. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #878736 15th Jan 2021 11:24pm
Chris_h
Yes same for me, new app won’t login, so have to use old app.
Post #878753 16th Jan 2021 7:52am
Sepp
Germany
No remote start option in Germany.
Saves the climate...
Post #878774 16th Jan 2021 10:13am
Gareth
ChrisH install the old app, get it working then install the new app. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #878778 16th Jan 2021 10:43am
