Home > Technical > Rear door central locking part unobtainable |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 741 |
What’s the part number on that, is there not one like that on the front doors also? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
15th Jan 2021 5:35pm |
souster4 Member Since: 11 May 2014 Location: West midlands Posts: 153 |
FQF000040 is the part number
15th Jan 2021 5:38pm |
Yep though that was on one of the other doors also but it’s not. I was thinking of the actuator. If you do locate a supple post here as I also need one soon. Searching for my first Defender...and started just as Covid hit, so talk about timing.
15th Jan 2021 5:51pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16892 |
Looking at the photo in this thread - https://www.defender2.net/forum/post715270.html - it wouldn'tbe too difficult to make a substitute for this, it is a very simply pivot and it looks as though one of the three "arms" isn't used anyway.
15th Jan 2021 5:59pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5424 |
I’m sure you’ve thought of this, but, if they only use two of the three holes in it, and they are fitted to both doors, could you swap your left hand side one with right hand side one, if it’s broken through a rod hole, or is it broken elsewhere?
15th Jan 2021 6:31pm |
It’s for the tail gate not the rear side doors Searching for my first Defender...and started just as Covid hit, so talk about timing.
15th Jan 2021 6:40pm |
Ahhh. Sorry.
15th Jan 2021 7:40pm |
Could this work, or be made to work
https://www.ebay.co.uk/itm/152754814340 |
15th Jan 2021 7:51pm |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 |
or the P38 RR part DBP5004L
15th Jan 2021 8:37pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1027 |
I have one on the bench since i removed the CL from the rear door, however it will go back in soon,
I'm happy to post it to someone if they can scan it for measurements for 3d printing, then send it back if this helps other than that, i can do some measurements for you, As Blackwolf said, only 2 of the holes are actually used. |
15th Jan 2021 10:00pm |
Thanks for your replies everyone. There's certainly some options to go at thats for sure. I think its got to be fairly similar to the original as the pressing of the door has a recess to suit the motion of it.
15th Jan 2021 10:35pm |
Badger110 pm sent
130dreamer Member Since: 29 Feb 2008 Location: Romford Posts: 100 |
I think I have a couple of spares of those.
Will have to go to the lock up to check so will be tomorrow before I can get back to you. |
16th Jan 2021 1:17pm |
If you have more than one that you are selling can I go on the waiting list 😁, after the op first obviously Searching for my first Defender...and started just as Covid hit, so talk about timing.
16th Jan 2021 1:27pm |
