![]() | Home > Puma (Tdci) > Heated Seats not Working - Any Ideas |
| Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327
Electrics aren’t my strong point either but maybe you could unplug the base and test the current with a multimeter on the car side to see if it’s being delivered. That way you know what way (car side or base side) you should start to investigate.
Before I had my defender I had zero tools and had never done work on a car before. Now I have all the tools and bits so that I can fix most things myself |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
test for voltage with a multimeter at seat plug to start with
| AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1073
I doubt it's the element. Normally just the drivers side that breaks due to movement when you change gear. Be a bit of a coincidence for them both to be faulty.
Were these factory fit? Not sure if available in 2007. Multimeter as other have said, then check the relay. |
| bobcat Member Since: 10 Feb 2012 Location: United Kingdom Posts: 12
Could still be both elements failed. It's not uncommon for seat bases to be swapped when the drivers side gets a bit tired. All the puma heated seat failures I've had have been caused by the wire breakage where the element connects in the base and in each case I've been able to solder it up. Usually fairly simple to see and do once you get the seat base apart and peel away the sticky stuff where the wires join. If the base fails the back does too.
| Edpike Member Since: 04 Jul 2020 Location: NI Posts: 35
Sorry, should had said they are factory fit heated seats. I will try the multmeter and check for resistance. Is the full seat on the same circuit?
| Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039
Filament in the seat being broken is my guess with the vehicle at the age it’s at.
Only takes a coffee spill to soak through and rust the wire and it’ll break. Check your voltage first, go from there |
| Racedriver Member Since: 24 Jan 2019 Location: Buckinghamshire Posts: 122
I have just repaired my XS heated seats. There is a plastic zip lock that splits the outer upper and lower seat covers. There are 2 wires going onto the heat pad for the backrest part. The yellow wire goes onto a strange small round part and from there onto the heat pad. This yellow wire from the loom had broken off at the joining point to the strange round thing. A very fiddley soldering job but re attached and all good to go.
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6054
Mine did the same. The small round thing is the heat sensor, so if it gets to hot it stops the power/heating. It also stops the seat from working just after you have soldered the wire to it, making you think you haven’t solved the issue.
Can’t think how I know that. |
Cheers for this - I will check over the weekend.
Update - Mine now work!!!!!!!!
| Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 228
Have just done a heated seat repair this morning on a sales defender at the local indi. Same yellow wire broken off on the button thermostat. So thanks for the advise. All working fine now, and off to the new owner tomorrow. Total time 1hr.
Ashbyandy. 👍😀 |
Great news and I will have a look at the weekend.
Just completed the drivers seat and I am glad to say that this was the issue and a relatively easy fix - assuming you have 4 hands to solder the wire back to the thermostat! (My wife was dragged into it). I have taken some pics and will post them on a separate post entitled Defender Heated Seat Fix. Once again, thanks for this, just the passenger seat to do...
| All times are GMT |
