Home > 130 > Electrics in the back
Dowks
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Keswick Green
Please could I ask for some advice on the best way to bring power into the back of my 130?
Looking to run a fused distribution block inside a waterproof box in the back to run a work light, fridge, usb power and a compressor for bike tyres.
Post #878366 13th Jan 2021 11:06pm
Mine's a 110 but the principle is the same: take a cable large enough for all of your needs from the battery via a large fuse, along the chassis and up into the body at a convenient point. When I did mine, it was part of a split charge installation but the idea is the same from a single battery.
The cable on the left of this picture is 70amp (10 sq.mm from memory) and is protected by a 60amp fuse. It exits the battery box top left and then runs along the chassis in a protective flexible conduit and comes up near to the rear lights. Beware of getting too near to the exhaust and protect it against heat if necessary.
At the other end, it depends what you want to connect it to. If you're using an integrated fuse box such as a Blue Sea, you may be able to terminate the cable directly to it with an appropriately sized ring terminal. For my particular installation though, I terminated the cable on a bus bar that allowed me to take power in different directions from that point:
There's more detail about all of this in my build thread here: https://www.defender2.net/forum/post717755.html#717755
Hope that helps. Darren
110 USW BUILD THREAD - 200tdi 90 BUILD THREAD - SANKEY TRAILER THREAD - Instagram: @landroveranorak
Post #878382 14th Jan 2021 8:38am
Dowks
Darren
Thank you, really does help, have not done any electrics on it before and was looking for some guidance, really appreciate your response. Need to get some bits ordered.
https://www.ringautomotive.com/en/product/RSU60
I was thinking of using this as the distribution point
Post #878385 14th Jan 2021 8:43am
That looks neat. I haven't seen that one before. Darren
Post #878387 14th Jan 2021 8:52am
Site Copyright © 2006-2021 Futuranet Ltd & Martin Lewis
