Home > Technical > RAI vs map
johnnyha
1996 Defender 90 300 Tdi CSW Epsom Green
RAI vs map
I'm considering a full sealed air system (nugget stuff) and wondering whether to include an RAI. My concern is whether this (the RAI/snorkel) would be restrictive to the map on my 2.2 TDCi. Any advice appreciated - fwiw it's very unlikely that I will ever be wading above the side air intake or in dusty climatic conditions
Post #878168 13th Jan 2021 11:42am
It depends on the RAI you choose. My Nakatanenga RAI is far less restrictive than the standard intake, and probably the least restrictive of any RAI. I seriously doubt that removing it would make any perceptible performance difference.
Post #878173 13th Jan 2021 11:55am
bankz5152
Short answer. No.
Long answer depends on how mapped, what turbo etc...
Post #878174 13th Jan 2021 11:55am
JOW240725
BAS published quite a bit of research on just this, if you look at their site or google it hopefully you'll fine it. It's on here too somewhere, someone might be kind enough to show links. James
Instagram @suffolk_rovers
Post #878188 13th Jan 2021 12:49pm
As Blackwolf says, it very much depends on the choice of RAI. I've got the same one as him, Nakatanenga, which does away with the restrictive duct between intake and airbox. Fitting this alone has transformed the way the vehicle drives to the extent that I've pushed the need for a remap way down my list of priorities.
Somebody else on here recently reported similar results when fitting the Nakatanenga induction kit, which does essentially the same thing but without the RAI. Both retain the standard air box. Darren
Post #878189 13th Jan 2021 12:56pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
I have very recently had a BAS remap and mine has a Mantec RAI and Nugetstuff airbox. No issues and drives superb - very noticeable improvement. Rgds.
Chris
Post #878212 13th Jan 2021 2:27pm
Oldowner
I have the genuine Land Rover Puma RAI on both my Puma 90 and 300tdi 90. It didn’t make any noticeable difference to the Puma but killed the performance of the 300tdi.
Post #878549 14th Jan 2021 11:52pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Safari RAI on mine, with the Nugget pipework and the airbox modded and the Twisted remap it came with - lovely!
Post #878599 15th Jan 2021 1:18pm
