Home > Puma (Tdci) > HELP. 2013 Defender 2.2 puma immobiliser fault
Crosslanes
United Kingdom 2013 Defender 110 Puma 2.2 CSW Baltic Blue
Hi all my 2013 2.2 puma is playing up, it cranks for a second then non start immobiliser red light stays on solid, here’s what I have tried
1. Changed fob battery and checked fob is transmitting a signal
2. Plugged in diagnostics and no communication with immobiliser module (every thing else talks ok no fault code in engine ecu)
3. Checked every fuse and relays all good and dry
4. Checked 10as box connectors all good and box is dry and lives and earths all seem present at 10as
5. Can get it to start by flasher battery terminals but back to fault once switched of again
6. Don’t have EKA and can’t reade out the ecu due to non communication with 10as
I’m thinking 10as box fault So I guess my question is there a bypass for the immobiliser side
Thanks in advance Paul
Post #796392 2nd Oct 2019 8:03pm
MartnH
Australia
Hi
short answer is no
I had a similar problem with my MY13 110. 2.2 the 10as in my car is the early puma BLACK 10as.
in the end, I have to replace the 10as and upgrade the entire system, inlcuding key fob...and now I have a shiny one like the evoque keyfob (or late puma key fob
Post #798624 18th Oct 2019 12:09pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Re: HELP. 2013 Defender 2.2 puma immobiliser fault
Honestly, man, even if there was a way to deactivate immobilizer & alarm (and take that car right away Smile ), how could you want us to tell it to anyone on the internet ? Don't you want your Land Rover to be safe ?
Just go to your JLR reseller, prove your ownership + identity and get your EKA code.
P.S. there you're asking very difficult questions while having just 8 posts ... Cow
Post #798648 18th Oct 2019 3:44pm
Crosslanes
Thanks for all the replies, in my case the 10as was just programmed out for £60 and problem solved for ever then I added a insurance approved cat 1 aftermarket alarm which is a must and off course the factory key chip side stays active. Thanks again
Post #798804 19th Oct 2019 9:08pm
Crosslanes
Just to add, in our case the fault with my car would not let you communicate diagnostically with the immobiliser or enter the EKA code and after watching the guy reprogram my car in 15 minutes I would not rely on the factory system to protect any Defender
Post #798807 19th Oct 2019 9:13pm
s55shh
I've got this fault now (and mines a 2015 with the later type ECU). Its currently stuck on the ramp in a local independent specialists. Before I spend £800 on new ECUs and keys, I'm interested to hear more about the coding guy who worked around it. Who was it?
Post #877990 12th Jan 2021 4:24pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Just a thought - but you dont have both key fobs in the cab at the same time - this will stop the engine starting if they are to close together.
Just a thought and shared experience ..
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #878001 12th Jan 2021 5:04pm
s55shh
I've only got one coded key. I bought a spare but they were unable to code it.
It seems as if the ALM has corrupted its software, probably due to car battery going flat. Its now locked down and diagnostics can't see it.
Post #878072 12th Jan 2021 8:35pm
s55shh
it looks like the only options are a new system from LR at about £800. or a bypass which deletes the immobiliser/alarm/central locking but reliably starts the vehicle for a lot less. I'm now wondering if fitting an aftermarket alarm alongside the bypass would be a preferable way of solving the obvious weak point. Glad I'm not halfway across the Kalahari Desert hey
Post #878165 13th Jan 2021 11:35am
