Home > Puma (Tdci) > Battery Positive Terminal Bolts
Hello folks,
Can anybody confirm the size of the bolts that secure cables to the standard battery positive terminal, please? I'm pretty sure that they're M6 but have a nagging doubt that they might be M8 Rolling Eyes
Many thanks Very Happy
 Darren
Post #877940 12th Jan 2021 12:28pm
I seem to recall that they are M8 flange head, but this is based on an (a) my (senior citizen) memory and (b) inspection of my stock of HD crimp terminals, neither of which is a particularly reliable method. Sad
Update: I've just checked the parts catalogue which lists an M8 screw for the megafuse but makes no mention whatsoever of the flange head screws holding the non-megafused leads to the clamp assembly. These screws don't seem to be identified anywhere, so presumably in the tiny brains of the LR directorate should only be supplied as part of the £80+ battery clamp assembly.
It seems likely however that if the megafuse terminals are M8, the others are too (but remember my caveat above).
Post #877945 12th Jan 2021 12:48pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
M8 or 7.9 according to my cheap digi calliper 😂
Post #877948 12th Jan 2021 12:57pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Yep, M8. Rgds.
Chris
Post #877951 12th Jan 2021 1:04pm
Ah ha, thanks chaps! Darren
Post #877957 12th Jan 2021 2:01pm
Ianh
The easiest way to check a bolt size if you can access to the bolt head or nut is to see what socket / spanner fits it. I.e an m6 bolt head / nut will be a 10mm socket / spanner and an M8 will be a 13mm socket / spanner. You get a rare one off bolt that has a larger or smaller head but the vast majority of nuts and bolts follow the standard metric sizes, tables of which can be found on the web.
Now I know all the posters on this thread know the above, so just highlighting for others that may not. And guessing that on a cold wet winters day, like me, LRA would rather ask the question on here than start pulling the truck apart to see what socket fits Very Happy
Post #877958 12th Jan 2021 2:02pm
Hi Ian,
You're right about not wanting to go diving under the seat box! Unfortunately though, LR have a habit of using odd sized bolts. e.g. M8 thread but with a 10mm head for instance, so it's not always clear cut Sad Darren
Post #877959 12th Jan 2021 2:07pm
Dinnu
Yes, and M6 with 8mm head across flats. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #877963 12th Jan 2021 2:23pm
Ianh
LRA, I’m assuming you are looking to connect leads for an Anderson connection or CTEK connection outside the battery box. I’m contemplating the same for trickle charging etc so are you thinking of connecting the positive to one of the two bolts and perhaps doing the bolt mod on the earth clamp so you have a longer bolt on the earth clamp (so it can be tightened down correctly) then the additional ring connector for the new cable placed on top and a second nut to clamp that down ? If so then you could do the same clamp bolt mod on the positive terminal.
These are options running through my mind at present, so people’s views on those options would help in my deliberations.
Post #877965 12th Jan 2021 2:28pm
Martin
Site Admin
You can clearly see from the caliper photo, that's an M8 bolt with a 10mm AF hex head above the flange.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #877967 12th Jan 2021 2:30pm
Yeah, it's an Anderson connector I'm planning for. I've already fitted a longer bolt to the earth terminal to allow a second battery connection and there's capacity there for another ring terminal. I want to use the supplied bolts on the positive terminal though, as I don't want to mess up the fitting of the rubber boot. Darren
Post #877971 12th Jan 2021 2:41pm
Sadly this rule-of-thumb falls flat on its face when LR in their wisdom use flange head fasteners, which is something they do a great deal. A flange head fastener generally has an AF size one standard size smaller than a conventional hex head fastener of a standard size, so in this case an M8 thread fastener, which would normally have a 13mm AF head, has a 10mm AF head (10mm being the next "standard" size down from 13mm, of course).
You will also find a lot of fasteners on modern Landrovers (and on other vehicles, especially Jap ones) that are non-preferred sizes, which is a major pain in the whatnot. For example, there are several metric thread fasteners on a Defender with a 12mm AF head instead of a 13mm AF head.
On Defenders we have the additional thrill of still having Unified and British Standard thread forms. Your front axle, for example, has a bizarre combination of metric standard, UNF and BSF threads, all of which require different size spanners!
Post #878039 12th Jan 2021 7:03pm
Co1
I used to have an old Peugeot that was littered with 5 sided bolt heads. That was an utter pain in the wheel nuts I can tell you!
Post #878064 12th Jan 2021 7:56pm
Pacha
[quote="blackwolf"]
Further compounded when the fitting involves a nut and bolt & the bolt head is a different size to the nut Big Cry Rgds.
Chris
Post #878067 12th Jan 2021 8:13pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Now that bit of info interests me. Wondering whether this is a potential for reasonably priced security fasteners Smile Idea
Post #878075 12th Jan 2021 8:51pm
