Home > Td5 > What’s this please ? |
is it the water pump ( no )
10th Jan 2021 6:37pm |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 509 |
Idler pulley IIRC, to give more wrap to the alternator pulley.
10th Jan 2021 6:40pm |
Gabriel Member Since: 05 Oct 2020 Location: Gardanne Posts: 1 |
Hello the pulley #7 is the visco-fan pulley.
10th Jan 2021 6:42pm |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 843 |
Viscous fan , that makes sense 👍
I see you can buy a bearing separately, Anyone done / changed one ? It just sounds dry and rumbley Thanks for your time and input |
10th Jan 2021 6:47pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2199 |
As already said above, no.7 is only a pulley for the fan. I did mine a few years ago. Easy enough to do, just takes a little while depending how much you strip off to do it. I did it with the rad/intercooler removed and the front panel off but you could do it without.
Good guide here: http://www.discovery2.co.uk/Fan_bearing.html Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
10th Jan 2021 6:50pm |
Only an idler pulley on mine as removed fan years ago......
10th Jan 2021 7:18pm |
