Home > Maintenance & Modifications > Do I need a 2nd battery to power spot lights
C&M
Hi.
I want to install a couple of spot lights on the roof rack, one on front and one on the back.
to be used when camping.
should I install a second battery for this and if so where is the best place to locate it? Defender D250 HSE
Dender 110 XS - sadly gone
VW Polo
VW Caravelle - Gen 6
Post #877287 9th Jan 2021 5:07pm
You don't need a second battery but it does depend on how you plan to use them. If, for example, you intend to have them on for long periods when the engine isn't running to light up your camp site then you risk draining the battery. In that case, a second one is a great idea. I've done exactly the same for that purpose.
The traditional place for a second battery is under the passenger seat alongside the main one. It's pretty tight and the exact configuration will depend on which combination of batteries you go for. There are lots of threads about second or dual battery set ups on the forum and the search function is your friend. To get you started though, here's a link to what I've installed:
https://www.defender2.net/forum/post714105.html#714105 Darren
Post #877293 9th Jan 2021 5:20pm
C&M
thanks for the link. I will take a look at your link when back on my laptop as planning to use them as you describe
Thumbs Up
Mark Defender D250 HSE
VW Polo
Post #877296 9th Jan 2021 5:28pm
If you opt for an LED based lamp (and for camping a flood beam is likely to be more useful than a spot beam) you should find that they have a relatively low current draw and can be used for quite a while without problem.
Post #877328 9th Jan 2021 6:58pm
C&M
Thanks Blackwolf I will look into LED's as I hadnt thought about that and for the pointer on flood vs spot
Darren - I enjoyed reading your post but not sure I could undertake that . I am limited on skills and time unfortunately Defender D250 HSE
VW Polo
Post #877346 9th Jan 2021 9:11pm
Hmm, there are lots of ways to do a dual battery system but, relatively speaking, mine is not the most complicated. Darren
Post #877375 10th Jan 2021 12:40am
