![]() | Home > Technical > Key fob, immobiliser, problem ? |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 697 ![]() ![]() ![]() |
If the horn sounds that could mean it is one of the door or bonnet switches showing as open?
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 ![]() ![]() ![]() |
But it do that if I’m trying to start it ? , I know it will if I'm Trying to lock her up .
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1137 ![]() ![]() ![]() |
Maybe just the fob's battery?
Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 371 ![]() ![]() |
I have the same/similar problem.
I have two fobs: Fob 1. Works as it should. Fob 2. Works in the way described in the original post. I have tried and tried, but found no way of getting it to work as it should. I have just lived with it, but it is annoying. It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
The most annoying thing is the horn going off twice every now and then and people think your trying to get there attention
![]() The immobiliser lights flash different when it’s not going to start ![]() |
ozy013 Member Since: 10 Feb 2014 Location: Melbourne Posts: 105 ![]() ![]() ![]() |
I had a similiar issue over Christmas, after returning from a Vic High Country trip. Car Battery is only 7 Months old and I replaced the fob battery when I serviced the Defender in November.
So I went to start the vehicle, dash lights came on, horn sounded once, but no start....nothing, not even an attempt to crank. Central locking was also not working, but would lock with the key. Put jump pack on battery, still no attempt to crank. Checked battery voltage, it showed perfectly healthy battery. Checked relays, and earth points, all good. Checked starter motor, when my mother tried to crank, there was no signal to the starter. It was then that I though ![]() I always replace both fob batteries once a year when I service the Defender. |
Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589 ![]() ![]() ![]() |
Did you rematch the fob with the ECM ? |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
The Indy who service my 110 always asks for both fobs and changes the batteries annually. Last year I got the phone call to collet the vehicle , on arrival he said sorry it isn't ready I can't get the fobs to work and the vehicle won't start I have gone through twenty batteries and nothing changes and I don't know now which were the batteries that came out of the fobs. The batteries he had ben trying all came in a Land Rover blister pack. with a good expiry date. I sent SHMBO to a DIY store and told her to get some Duracell batteries, on her return he popped them in the fobs and just like magic they worked. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
No I didn’t , is there a process ? Stew |
