Home > Maintenance & Modifications > Remote Battery (Jump start) Terminals |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 955 |
Wouldn’t the door side of the seat box be better? Sheltered from feet and easy to access with the door open Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
8th Jan 2021 6:29pm |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5765 |
I’m thinking of the same upgrade. I was thinking in this location, which I think is where Leamreject means.
Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
8th Jan 2021 6:32pm |
Thanks Grenadier.
Exactly where I’m going to put mine. Out of harms way simple to connect and perfect for ease of access Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
8th Jan 2021 6:35pm |
Just need to move the steering wheel to the popper side on this vehicle pictured.... must have been a Friday build Ride like you stole it!!
8th Jan 2021 6:37pm |
8th Jan 2021 7:58pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2496 |
I'm confused. Where abouts is Cubbington in Italy? Defender 90XS SW
8th Jan 2021 8:51pm |
I'm confused. Where abouts is Cubbington in Italy?....
It’s in a similar place to the battery on a Defender.... “difficult to get to but worth it when you do” Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
8th Jan 2021 10:32pm |
What I want to know is what a Leam is, how how it feels to be rejected by one? Monsieur Le Grenadier
9th Jan 2021 9:35am |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1351 |
I've looked at doing this, but not got round to it. Giving other's a jump start from the Defender is a pain, getting access to the battery.
Those Blue Sea terminals seem ideal for the job. There is very little clearance between the seat box side and the door when it is closed. If you want to fit them there, a recessed panel may be required, so the terminals don't stick out. -On the top of the seat box, near the seat rails may be an option, but could be in the way for seat adjustment? Fitting to the front of the seat box would be a straight forward job. For charging I have made up leads to connect my chargers to a cigar socket inside the rear door, the usual 'Purple wire' connection described on the forum. I run a 240v extension lead into the back, through the door seal. The charger is completely inside the Defender. Due to short runs in the winter, it usually needs a top up charge every 2 to 3 weeks. |
9th Jan 2021 10:40am |
Leam is short for Leamington Spa... I’ve been rejected Happy to be in Cubbington, although it is overrun buy JLR employees, New Defenders are breeding everywhere..... Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
9th Jan 2021 11:53am |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 305 |
Have you considered the military option?
https://www.ebay.co.uk/itm/British-Militar...1195.m1851 These are used on the wolf 24v so should be capable enough. The plug that goes with it is available but you need to do a bit of research to find one that fits, unless you go for the military one but they are pricey. |
9th Jan 2021 8:55pm |
htb2 Member Since: 02 Nov 2018 Location: aberdeenshire Posts: 509 |
What size Anderson plugs should be used 175A or 350A?
9th Jan 2021 9:49pm |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 149 |
Htb2 - The SB175 is rated up to 280A, the SB350 up to 500A. I believe the starter motor on a 2.4tdci is rated at 300A so theoretically you need the SB350. In reality you are often only helping out the vehicle battery when jump starting, and that only momentarily. I made up jump leads with an SB175 and good heavy cable and have never had any trouble. I've seen a lot of commercial offerings built the same way. SB350 is a very large connector and not therefore very convenient if you don't have to use it.
Apologies to discomog, who said no Anderson connectors! |
9th Jan 2021 11:22pm |
Thanks SWT. That was my thoughts as well, but thought better check. Should have a made up set of short leads and one 175 anderson connector in the sheds somewhere. Just need to make up a new set of jump leads to mate to the other half of the anderson.
9th Jan 2021 11:28pm |
