![]() | Home > Maintenance & Modifications > Defender 110 Rear Door Drawers |
Very nice. You can't beat a bit of well thought out storage
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
AcidHawk Member Since: 07 Sep 2012 Location: Gauteng Posts: 4 ![]() ![]() |
Thanks,
but most importantly ... the boss is happy. ![]() |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
Good job
![]() A word of caution, the bottom piece of plywood in the footwell may be susceptible to moisture as is common in 110's at the base of the B pillar and door. Perhaps lining underneath it with some form of barrier or a few coats of paint may help ![]() |
Thanks for the pointer.
Yes I have had moisture there before. I was actually looking at putting a couple of layers of fiberglass on the part that goes in the foot well. In addition to that I am going to fiberglass the compartment that holds the water tank as I have had that thing leak before as well. |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2361 ![]() ![]() ![]() |
Be careful you don't open all the drawers at once, your 110 will fall over
![]() Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
![]() There is a bunduawn on the other side ... so I had to put the drawers on the drivers side to balance it out... ![]() |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3726 ![]() ![]() ![]() |
Nice work!
