Home > Off Topic > Winter Fuel Additive
discomog
Just wondered if anyone has had experience of using a diesel winter fuel additive. I've had problems with my tractor fuel system waxing up during our recent cold weather. Can anyone recommend a brand of additive to help reduce waxing? Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #876412 5th Jan 2021 4:27pm
gilarion
Is this for red diesel as I thought ordinary diesel had an additive mixed already to stop waxing? Do not know if the same is true for red For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #876421 5th Jan 2021 4:54pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
As gilarion alludes to you don’t need additional additives to prevent this if you use regular forecourt diesel.
Use of a periodic EGR/DPF cleaner would be more beneficial, especially for vehicles that only do short journeys and never get to perform any form of DPF re-gen Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #876424 5th Jan 2021 5:22pm
Rashers
Maybe your issue is the Diesel Bug problem where modern diesels have a percentage of biofuel which if left in a vehicle over time gunks up the fuel lines and filters. It’s the kind of thing which a tractor would be susceptible to. Boats and generators also have a similar issue.
Post #876449 5th Jan 2021 6:57pm
discomog
I think Gilarion may have solved my problem in so much as the tractor has a mix of red diesel and duty paid diesel. As I only use the tractor periodically it may be worth while draining off the mix and filling with duty paid diesel. Defender 90XS SW
Morgan Plus 8
Post #876450 5th Jan 2021 7:00pm
Leamreject
Biodiesel content is maxed at a 5% mix and I thought that forecourts had to clearly display if their fuel included it?
Some manufacturers don’t support the use of it in modern diesels at any diluted mix, so I would err on the side of caution and avoid it.
Can anyone here provide more detail? Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #876453 5th Jan 2021 7:07pm
Rashers
https://www.fueltek.co.uk/what-is-the-dies...-avoid-it/
I think the biodiesel percentage is a legal requirement. I may be wrong.
I also don’t think apart from the colour there is any difference these days between forecourt diesel and red diesel. It’s just a duty thing. All modern tractors are Euro 6. Just like a modern truck or car.
You are correct that modern common rail Diesel engines shouldn’t run on pure bio fuel diesel.
Post #876457 5th Jan 2021 7:25pm
AMBxx
Didn't it used to be standard practice to add a gallon of petrol in winter to avoid waxing?
Post #876552 6th Jan 2021 8:10am
Leamreject
Best if you avoid Petrol anywhere near a Diesel system nowadays, the damage to other fuel components, including the engine far outweigh any presumed historic benefits Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #876553 6th Jan 2021 8:16am
discomog
In the 1960's, Plant Hire companies used to put a gallon of paraffin in their diesel tanks in winter to reduce waxing. Defender 90XS SW
Morgan Plus 8
Post #876555 6th Jan 2021 9:12am
How old is your tractor, Discomog? Darren
Post #876556 6th Jan 2021 9:13am
discomog
It's a Leyland 344, 1972. 3.4 litre normally aspirated BMC diesel Defender 90XS SW
Morgan Plus 8
Post #876560 6th Jan 2021 9:28am
Ah, so no worries about EGR's, DPF's or high pressure fuel systems then.
The diesel bug issue is a good call if it's only used occasionally. Diesel in the UK should be more than capable of withstanding the cold that we typically experience. Darren
Post #876564 6th Jan 2021 10:02am
jst
Add 2l.of petrol.
We did it as standard practice with tdis for cold weather environments. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #876567 6th Jan 2021 10:10am
grafty99
Having recently dropped the fuel tank in my daily driven Td5 90, I can confirm that bio diesel bug doesn't just effect vehicles that aren't used frequently. Luckily I caught mine before it showed any symptoms or problems. I have now treated all of our diesel vehicles with biocidal additive Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #876568 6th Jan 2021 10:10am
