Home > Puma (Tdci) > 110 considering to buy please have opinion and what's wrong?
Hunky Gibbon01
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Zermatt Silver
Hi all,
I saw this and it seems ok. Use to commute to work 13 miles each way and camper trip (only need bed, food, water/beer).
Any opinions and anything wrong. Thank you
https://m.facebook.com/groups/115762705206...highlights
Post #874782 27th Dec 2020 12:00pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Worth a look - obviously ex-utility company - that's not necessarily a problem if maintenance history, rather than service history is available.
Then usual checks - bulkhead and chassis rust, transmission clunks above normal Smile , oil leaks and so on.
Good luck Thumbs Up Just because you're offended doesn't mean you're right.
Post #874790 27th Dec 2020 1:03pm
Oldowner
Ex western power distribution, overhead line vehicle.
Ridiculous wheels and tyres. Can’t believe it “runs and drives superb” with them on.
Post #874801 27th Dec 2020 2:39pm
From what little you can see before b***y facebook throws you off if you don't have and won't create an account, it looks quite tidy, but the comment above about the wheels and tyres is very sensible (they are absurd, and unless you're a weirdo would want to change them as soon as possible) also note that the winch is an ex-utility rigging winch with a large drum and hence will have a fairly low line pull, so is not much use for an off-road vehicle. There is also a good chance that it will have the complex electrical system typical of ex-utility vehicles, which is OK if it is mainly intact with all the extra kit still fitted, and if you are an electrical enthusiast, but can be a bit of a nightmare if it's been hacked about and had things removed.
Bearing in mind that the seller will almost certainly think that both the tyres and the winch add massively to the value of the vehicle (which they don't) you may find that it is over-priced for what it is.
Post #874810 27th Dec 2020 4:22pm
CarMan
Mileage Question Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #874814 27th Dec 2020 4:38pm
camelman
Mine "runs and drives superb" with 35's on.....
The only problem with those is that they stick too far out of the standard arches to be legal.
Post #874819 27th Dec 2020 4:47pm
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
Looks tidy , do you have a budget to put things right , as mentioned before ...tyres ,winch and full service and maybe a clutch, ? If so go for it it’s a good blank canvas if bulkhead , chassis and engine are in good order.
I prefer td5 or tdi but no massive issue with puma , if using for adventure -overland and commute I’d swap rims and tyres for wolf and All terrains , bfg , coopers , maxxis, Micky Thompson’s are all good brands 235x85x16 or max 255x85x17. This fauve alone will cost over £1k but you’ll get £4-500 for tyres you have on it .
Go for it , buy it fix it and enjoy it👍 Have fun be happy
Post #874823 27th Dec 2020 5:00pm
kenzle8a
I looked at ex utilities before I bought my double cab, I’d rather one that’s fresh ex utility as at least that way you know someone else hasn’t tried to do anything to it, the wheels and tyres are certainly post utility life additions as all the ones i saw had smaller muds on.
You can also but a standard hard top for less usually, or at least that’s what i saw.
Post #874827 27th Dec 2020 5:16pm
Oldowner
It looks tidy as it has had a respray. I drive one of these daily. Unusually for a Puma, they are used as Land Rover originally intended!
There won’t be any Britpart service parts on it.
Steering is heavy due to the winch and hydraulic system and steering boxes take a hammering - As stated before, the winch is for erecting pole mounted transformers etc. You can also run hydraulic tools off the takeoffs on the front, should you ever need to erect a duckbill pole stay.
Post #874836 27th Dec 2020 5:50pm
Oldowner wrote:
...There won’t be any Britpart service parts on it....
Sadly I wouldn't count on that, since it has clearly had quite a lot done to it since being demobbed from WPD.
Post #874862 27th Dec 2020 8:30pm
