![]() | Home > Maintenance & Modifications > New LEDs - DAB meltdown! |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1887 ![]() ![]() |
Are you 100% sure it's the LEDs causing the radio problem?
My car (1994) clearly has old-school basic wiring, but I have a DAB head unit, and the RDX led indicators, and there is no issue. I initially had one of the little 'stick on' aerials inside the windscreen - up here, where the DAB signal can be patchy, reception was hit and miss. I then fitted a proper powered aerial on the roof, combining FM and DAB, and the reception is excellent. It just strikes me you could be chasing a fault that doesn't exist? OTOH if you have a newer car, with more modern electrics that are susceptible to this kind of interference, then maybe all of the above is irrelevant? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 821 ![]() ![]() |
I'm not sure what the solution is, but the same happened to me when I fitted LED reverse lights to my Discovery (no issues with interferance before this).
As I only use reverse for parking not a great issue but interested to hear the solution from others. ![]() ![]() |
MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 361 ![]() ![]() ![]() |
Mine is a 2013 Puma. Live in E Lothian and work in Edinburgh so DAB coverage is as good as can be Expected. In fact it was fine before installing these LEDs. You can hear it kicking in when you flick on the sidelights or press the brake pedal...I’m considering the dedicated aerial but worried shelling out £75 will be money wasted if the issue persists. |
So after a really too strong cup of coffee this evening I determined to go out and get to the bottom
of this. After a process of elimination, I confirmed it was indeed the LED front sidelights causing the interference/loss of DAB signal. Nearly took them out on the spot, but thought one last try. Stuck ferrite clips right behind the lights, then another behind the ‘radio side’ of the loom. Interference gone. |
