Home > Off Topic > Installing t&g floor
Bluest
Being a bit of a chav I’ve installed a few click lock laminate floors over the years with no problems. However, my Wife is getting ideas of grandeur and want something better in the hall. We’ve seen a nice engineered wood that we like, but it’s t&g not click together.
I understand there are three ways to install this. Glue, nail, or special screws. It being laid over a chipboard sub floor. Any suggestions on what’s best and why? 2007 110 TDCi Station Wagon XS
Post #874727 26th Dec 2020 6:45pm
Sulisuli
Last time I did an English oak T & G floor I hired a nail gun and nailed it on the lower part of the groove pre putting the tongue into the groove, it gives an invisible joint that doesn’t move provided the substrate floor is solid. The hire company sold me lost head nails and the gas propellant cartridges on a sale or return basis.
The shoe of the nail gun is angled so you can’t get it wrong Thumbs Up
Please wear the correct eye protection and have a few practices with the nail gun first, hope this helps and your good lady enjoys your DIY skills. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #874731 26th Dec 2020 6:58pm
Bluest
It it ok to nail it even if I’m using an underlay? I guess it is. 2007 110 TDCi Station Wagon XS
Post #874732 26th Dec 2020 7:19pm
LR90XS2011
in the bedroom I have real oak floor boards straight over joists I used special screws in case I had to lift it it again, same theory but with screws, you will need a battery drill and some patience takes a bit longer than a nail gun.
found OSMO oil a brilliant coating, my floor is american oak pre treated with OSMO
in the lounge engineered oak over floor boards this floor was fitted by others they used a nail gun t in this case no underlay)
in my hall I used engineered oak parquet, that is glued down DEFENDER 90 TDCI XS,
Post #874733 26th Dec 2020 7:21pm
Sulisuli
I’m afraid I can’t answer that as I didn’t use underlay (it was quite a few years ago) but I don’t see why you can’t but someone maybe along shortly to tell us more Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #874734 26th Dec 2020 7:24pm
Bluest
I was under the impression the nail goes through the tongue side, glad you mention doing it through the groove. 2007 110 TDCi Station Wagon XS
Post #874735 26th Dec 2020 7:39pm
Sulisuli
LR90XS2011 wrote:
in the bedroom I have real oak floor boards straight over joists I used special screws in case I had to lift it it again, same theory but with screws, you will need a battery drill and some patience takes a bit longer than a nail gun. (screwed through the bottom of the groove)
in the lounge engineered oak over floor boards this floor was fitted by others they used a nail gun through the lover groove in this case no underlay
I’m almost too scared to ask what the “lover groove” is in the above posting, at least you nailed it Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #874739 26th Dec 2020 7:59pm
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
Bluest,
I've used Tongue-tite screws in the past. http://www.tite-fix.co.uk/products/tongue-tite/. You can get them at Toolstation or Screwfix nowadays.
I used them to secure down 20mm solid oak T&G flooring with a 1mm ('ish) underlay. It's been down about 10 years, hasn't moved and does creak anywhere. Easy to use and has the advantage of the heads disappearing into the top of the tongue. Near the door thresholds I used a recessed hole and filed with a plug of oak.
I drove mine at about 45 degrees so you'll need to use the correct length depending on the depth of your flooring and whether you have 18mm or 22mm chipboard flooring.
Hope this helps and good luck.
Andy
Post #874741 26th Dec 2020 8:04pm
LR90XS2011
thinking about it you are right it is 45 degrees into the corner of the tongue was some time ago I did mine
previous post altered sorry (video attached)
Post #874742 26th Dec 2020 8:13pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
You can lay t&g as a floating floor in the same way the click systems work. Leaving a gap at the perimeter and gluing the tongues. Essential if you are doing it on an upper floor and are needing to maintain acoustic separation. Solid fixing can cause issues with movement on real wood so you are better of laying it a floating floor on an underlay.
TC
Post #874747 26th Dec 2020 9:18pm
chopcat
TC
Post #874748 26th Dec 2020 9:20pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Buy one of these;
https://www.mytoolshed.co.uk/porta-nails-m...zwQAvD_BwE
Watch this
Simples Thumbs Up
p.s. Don't use the screws, shank is too large unless you're fixing 20mm + thick boards and not engineered planks which are softwood core with a 2mm hardwood face, they will split
Post #874754 26th Dec 2020 10:44pm
