- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
boode
I have a non standard Webasto install in my 90
A simple switch one the dash turns it on and off
Three wires go into this switch - Red : Black and Brown
I wish to use a tD5 style switch through a relay to replace this switch
I used the Red as the pin 30 - Live feed in
Connected the Black to the pin 87 - output feed
Not sure where to put the brown wire
If connected to the black it blows the 1amp webasto fuse - now run out of 1amp fuses
Any advice will be much appreciated
24th Dec 2020 5:56pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
