![]() | Home > Maintenance & Modifications > Q about dual beam spot lamps |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
The Mudstuff (Bearmach) switches are all the same electrically. The only difference is the engraved fronts.
They are a copy of the Land Rover switch YUG000540LNF, which is designed to switch the earth of a relay - search on here, there's lots of info on wiring this switch. To switch your Warn lamps using two of these switches, you would need two relays - One with n/o contacts as the 'master' power relay. And one with c/o contacts to select beam type. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 210 ![]() ![]() |
Perfect thank you
