![]() | Home > Maintenance & Modifications > Replacement brake caliper |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
Defender calipers do seem to suffer from not having the rubber bellows that expand out to protect the piston like on most modern cars. Means the piston is more exposed and corrodes sooner and when you push it back, it potentially drags a load of dirt and debris back into the bore unless you clean it thoroughly. 2007 110 TDCi Station Wagon XS
