![]() | Home > Technical > Heater |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
coolant level ok
| pauldgray Member Since: 08 Aug 2020 Location: Hindhead Posts: 14
Yep
| Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 845
Does the heater valve move when you turn the knob inside (heater valve seams to be a cheep part on these and breaks often) Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
Yes, it works fine when driving along at 2000rpm but when stopped on idle the heat stops
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18040
This is fairly normal on a TDCi, and provided that the coolant level is well up there is not much you can do about it. The heater is extremely sensitive to coolant level, but will also vary enormously according to what the engine is doing.
| I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 886
Glad I have a 300tdi, it is always reliably luke warm
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3786
Pretty normal unfortunately. Mine a either cold or hotter than the gates of hell. No really middle ground!!
| All times are GMT |
