Home > Technical > 2006 TD5 defender driver demand 1 high
dorsetsmith
2006 TD5 defender driver demand 1 high logged dtc and top acceleration bad will check wire to accelerator start with
but look for more pointer
fuel filter good
MAF good
no oil ecu plug
checking wastegate re over boot limp mod moves from close to 1/4 open at 14psi and fully open at 20 psi
dtc cleared
Post #872557 12th Dec 2020 11:24am
geobloke
Hi dorsetsmith.
Good ol Driver Demand 1 fault, been chasing this one for years and still not settled on an absolute cause for it.
Driver Demand (DD) faults are reputedly caused by either worn accelerator pedal tracks (track 1 in this case) or a broken wire between the pedal and the ECU. This is the first place to start fault finding, but in my experience it was not these bits of hardware at fault.
What i did notice was that the DD fault started at the point of remapping and increasing boost presumably to or beyond the limit of the intake MAP sensor. The DD fault only ever occurs on heavy throttle, full boost (but not over boost), moderately to heavily laden and up hill either prolonged or steep). The interesting thing is that since I have backed off the boost the problem has ceased to happen. This leaves me to presume that there was/is an unbalance in the ECU mapping that under certain conditions a DD1 fault is triggered. My remap was not bespoke to my engine but a via mail. This may be the underlying issue.
But it might not...
Anyone else have more of a clue?!
Post #872759 13th Dec 2020 6:20pm
dorsetsmith
if it stop raining this week going check fuel presser at engine as top end power is down, all wiring and values to and from accelerator pedal to ecu ok so at a loss
Post #872763 13th Dec 2020 6:34pm
geobloke
Interesting read here - https://www.defender2.net/forum/topic65395.html - Turned out to be the ECU at fault.
Defo check FPR for leaks although this tends to exhibit as failure to start the engine rather than top end problems. Not saying it can't be the FPR but unlikely in my experience. Top end problems are likely to be fuel pump (lazy or old) or possibly corrosion around the the fuel filter union seals.
Post #872765 13th Dec 2020 6:45pm
dorsetsmith
fuel pump yes the lest one filter screen at the bottom of the pump full of black gung
seen that hoping not ecu
https://www.ecutesting.com/
Post #872768 13th Dec 2020 6:52pm
dorsetsmith
driver demand 1 foot off 0%------- 0.57 v
-----------------2 ----------------------4.48 v
---------------- sup---------------------0.00 v
driver demand 1 foot down 100% ----4.96 v
-----------------2 ------------------------0.42 v
-----------------sup-----------------------10.00 v
see up date below Exclamation
Post #872817 14th Dec 2020 10:00am
geobloke
I have seen that configuration of voltages before in another post/forum, if i recall they were using a hawkeye to diagnose it. I am afraid I do not recall the outcome.
Post #872820 14th Dec 2020 10:33am
dorsetsmith
I used Hawkeye to read from ecm
have checked battery to chasse ground and transfer box too
Post #872823 14th Dec 2020 10:51am
Martin
Site Admin
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #872824 14th Dec 2020 10:55am
dorsetsmith
thank martin
Post #872825 14th Dec 2020 11:08am
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Last week
defender went into limp mode and engine management light came on. No throttle.
Anyway driver demand logged and ended up with new throttle.
Been good ever since.
Post #872834 14th Dec 2020 12:14pm
dorsetsmith
this trouble no engine light dtc cleared no limp mode throttle working and will not stop with the liquid sun shin Rolling Eyes
at last fuel presser 3.9 bar Surprised
Post #872837 14th Dec 2020 12:20pm
geobloke
Ok, so do we think there are three faults that result in a DD1 fault being logged?
1) Engine management light on, no throttle - Pedal replacement appears to fix problem
2) No Engine management light on, throttle OK, goes in to limp home, reduced boost and RPM - ECU map and boost issue
3) No engine management light on, throttle OK, track 3 Supply voltage too high (10v) - Maybe fault with dash light cluster.
A place to start maybe...
Post #872890 14th Dec 2020 5:29pm
dorsetsmith
3) No engine management light on, throttle OK, track 3 Supply voltage too high (10v) - (Maybe fault with dash light cluster. Laughing )
the wastegate stuck open now free up and working one down
( moves from close to 1/4 open at 14psi and fully open at 20 psi )
See up date post below Exclamation
Post #872896 14th Dec 2020 6:05pm
dorsetsmith
Hawkeye read this from ecm Exclamation
Nanocon read this from ecm
I wood seem that Hawkeye is not read from the ecm correctly thank for all input
for pre 2002 two track pedal pots Exclamation filmware 4
Post #872936 14th Dec 2020 8:46pm
