![]() | Home > Maintenance & Modifications > Labcraft Scenelight Si9 - any good? |
backpacksandroofracks Member Since: 03 Sep 2019 Location: North Yorkshire Posts: 8 ![]() ![]() ![]() |
Hi Matt, I've one Labcraft Si9 mounted on the side of the rear canopy of my 130. I use it as a 'camp' area light for chilling under after the suns gone down. It's a really nice light, bright but diffused so quite soft and easy to work/cook/prep/chill under. Quality is great, rubber gasket is good, I placed a bead of bond between truck and gasket and then between gasket and light for ultimate waterproofing, no issues so far.
I have two Lazer Utility 25s used for reverse lamps but would think that Si9 would work more than well enough, provides more light than I was expecting and a decent throw for the size of the unit. Cheers, Joe. |
Jem_90 Member Since: 10 May 2019 Location: Oxon Posts: 54 ![]() ![]() ![]() |
I can recommend this Rigid scene light.
It is very bright and has a great flood pattern. ![]() https://www.rigidindustriesshop.co.uk/prod...1994922033 |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 408 ![]() ![]() |
Matt, I have not personally got the lab craft, but a few mates have had them and they are very good
I have the rigid that Jem has, however I wouldn’t recommend it. The light output isn’t great, it’s “ok” but for the money the labcraft is a much better option |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2389 ![]() ![]() ![]() |
I have 2 si8 lamps on my 90 for camping, not the same model but they are superb for campsite lighting, bright illumination but not blinding.
A bit tricky to photograph but a couple below. HTH Mo ![]() Click image to enlarge ![]() Click image to enlarge The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
