Home > Maintenance & Modifications > Where is my leak coming from
drakes
United Kingdom 2004 Defender 90 Td5 HT Auto Belize Green
I have a leak from the top of the driver's door, sometimes when parked if the rain is very heavy and sometimes when driving. I have resealed all around the windscreen and even taped all over the seal and windscreen rubber but the water still comes in. Hope the photos make sense. I have looked at the water ingress manual but it does not refer to this point.
Post #872327 10th Dec 2020 6:42pm
Rkcorry
The roof join inline with the trailing edge of the door is worth a look, it was in my case.
You could also try parking up or down hill to determine the point of entry.
Post #872328 10th Dec 2020 6:48pm
donmacn
Two other likely candidates - the alpine light window seals and condensation on the underneath of the roof as the weather gets colder. It probably isn't the windscreen itself. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #872330 10th Dec 2020 6:51pm
jst
What Donald said. More than likely running along gutter inside from windows or near back. Is the gutter dry below alpine windows. Do you park nose down or park level and leak is worse when slowing?
Does it leak when driving in rain? If yes then its near the front Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #872335 10th Dec 2020 7:36pm
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Same problem here. I've changed the alpine window seal and used Dinitrol seam sealant on what I think are all the potential entry points and it's still doing it. I need to get the roof lining out and have a systematic go at finding where it's coming in.
No more than a generous cupful of water generally gets inside, and it all empties neatly into my lap when I first go downhill, so the inconvenience could, I suppose, be worse.
Post #872336 10th Dec 2020 7:39pm
drakes
Rkcorry
Do you mean the join across the roof sort of above the driver's head?
donmacn
No alpine lights so that probably rules them out ( although it is a Land Rover) and the roof is fabric lined so no condensation also it leaks in summer rain as well as winter
jst
Normally park level but is worse when slowing and having sealed the windscreen does imply it is coming from the back but being an 04 plate it does not have the little vents on the rear panel
swt
Yes empties in my lap as well
Post #872350 10th Dec 2020 9:00pm
jst
Its coming in side or back and sitting in the channel then moving under braking. Roof join, also check rear roof return to back door at corner. All gutter to roof bolts are tight? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #872354 10th Dec 2020 9:12pm
Oldowner
Cracked mastic sealant where roof lower gutter section is joined to the roof panels. Rake out the sealant all around the roof with sharp chisel and refill gutter with Soudal Carbond (not sikaflex as not repaintable).
99% of the time it is this and not the alpine window seals at fault.
Post #872377 11th Dec 2020 12:20am
Greyman110
I had this too!
It was coming through the roof where the flat section meet the slanting front section. I used Captain Tolleys creeping crack sealer on it. Spent a few hours when it was dry and warm going over it every 30 mins and it hasn’t come back.
Post #872379 11th Dec 2020 2:40am
L110CDL
This is spot on as i had this and i just used what silicon i had to hand as i was getting fed up with a very wet lap Laughing
Coniston green ? Clayton.
Keeper.
Post #872510 11th Dec 2020 9:33pm
jocklandjohn
Scotland 1989 Defender 110 200 Tdi HT Oslo Blue
If you can take the headlining out for a bit, then poke a piece of kitchen roll into the inner U channel above the door you may find that it is (surprisingly) dry, and that the water is not coming down that inner channel which seems like the obvious location.
It may actually be coming from underneath it. The way the roof folds into the gutter area is a bit weird in that several pieces make up the gutter and if the the mastic in there is cracked the water can get in under the upper layer of alloy in the gutter outside and appear inside.
When I was building my lifting roof I got right in about it and was really surprised at the very convoluted structure and was finally able to determine where the copious amounts of water were coming from. Because of that folded structure water can actually come in anywhere along the sides and round the rear corner but all appear at the front in your lap (when cornering).
Oldowner is spot on. The actual offending bit is very near the outer (folded) lip of the gutter and you have to really poke the mastic in there - its hard to actually see what you're doing, but worth making the effort, AND go around the rear corner too as it can be a contributor. After I put a couple of tubes of PU mastic in there I no longer needed to wear waterproof over trousers when it was raining!
Post #872515 11th Dec 2020 10:16pm
Rkcorry
Another vote for Creeping sealer, though the leak was on the lower scale of things, the sealer did cure it.
Ad above, applied during warm dry weather, it dries clear, what you can see of it.[/b]
Post #872521 11th Dec 2020 10:51pm
drakes
Thanks for replies I think the consensus is tending towards the sealant in the gutter or possibly where flat and sloping roof meet so I guess now I will have to wait till the weather warms up to try and seal it.
L110CDL Belize Green
Post #872559 12th Dec 2020 11:41am
donmacn
When I suggested the alpine lights and condensation, I forgot I'd already sorted the roof guttering on mine.
There are some pics on my 'resto' thread, towards the bottom of this page. [url]https://www.defender2.net/forum/topic58538-15.html [/url] The last pic gives you an idea of the construction that jockland john has mentioned.
On the 'creeping crack cure' stuff - I've been a big fan of that too, and it did stop a few leaks I was having. However..... after a week's offroad trip back in September, some of them came back. I suspect the crack cure stuff dries quite rigid, and then over time, or with offroad use, the body flexes enough to break the seal. I had to get the windscreen resealed a few weeks ago and he used 'arvomast' - as I understand it a more permanently flexible seal.
I do now have a 'laptop leak' again, but now I reckon it's the alpinelights and I just need to go around them with the arvomast stuff.
Hmmm - posting the page link didn't work? What do I need to do? Donald
in the past..
Post #872560 12th Dec 2020 11:48am
L110CDL
Many thanks drakes Thumbs Up Clayton.
Keeper.
Post #872956 14th Dec 2020 10:20pm
