Home > Maintenance & Modifications > Switch engraving/etching
grafty99
Anyone got any recommendations for genuine switch engraving?
Basically I'm installing a webasto in my 90 and I want to add a genuine switch to control the heater when parked (momentary press will start the heater for 30 minutes)
My plan is to use a heated front screen or fog light switch and then have a switch blank face plate engraved to say HEAT or Webasto or similar - then just swap the face plates over. I don't really want to use a second heated front screen switch with its original icon as it won't sit right with me Laughing
I'm looking for a factory (or close to) finish - any suggestions? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #871320 4th Dec 2020 6:29pm
I know mudstuff does this Thumbs Up QRZ 2e0vpf
Post #871322 4th Dec 2020 6:51pm
grafty99
Do you know if they make their own GREENI?
Theirs look very similar to the bearmach ones (or vice versa)? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #871532 6th Dec 2020 10:44am
They have their own machine, so can do anything. QRZ 2e0vpf
Post #871597 6th Dec 2020 5:47pm
grafty99
Ah perfect, I'll be in touch with them tomorrow Cool 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #871600 6th Dec 2020 5:49pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
May be a group buy to make it worth their while - I would like one
Post #871658 6th Dec 2020 8:53pm
grafty99
Switch engraving is a no from MudUK - any other ideas people? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #871980 8th Dec 2020 4:37pm
D'oh, sorry! QRZ 2e0vpf
Post #871981 8th Dec 2020 4:41pm
grafty99
No worries, it was worth a try Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #871986 8th Dec 2020 5:31pm
gumdrop
Interested in this ... following Smile Cheers
Simon
50th D90 - my toy!
Freelander SE Td4 3 door - local run around
1958 Series 1- Rag top!
Post #872101 9th Dec 2020 11:11am
You could try asking your local jeweller, they engrave things. It's a little different but the principle is the same.
Post #872111 9th Dec 2020 12:04pm
rallysteve
I was contemplating trying a laser engraver add-on to my 3D printer to do switches before Bearmach/Mud started doing them.
Looks like there might be a market so maybe i should look into it a bit further!
Post #872117 9th Dec 2020 12:35pm
AJC
google search Autoflock
He does loads of custom bits like that and i know hes got a CNC engraver
Post #872129 9th Dec 2020 2:30pm
Dinnu
I used to be laser marking engineer for a company in the semiconductor industry. I still have access to those laser markers....
The problem is that would need a few switches to test and get the right parameters even though they are set to mark on plastic.. different plastics have different properties.
Maybe tempting to order a few AMR5432 Rolling with laughter . Previous owner simply used a hazard switch from a D2 for the rear working lights.... granted, it works....been tempted to replace it as it annoys me a bit, but then working light switches are readily available, but when I searched they were 3x the price of a blank one. Add shipping costs.. and easily will be as expensive as a full tank of diesel. I just need an on/off supply to a relay!! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #872131 9th Dec 2020 3:29pm
boode
George - I remembered this old post where a Cruise Control switch was made by scratching off the black paint using a sticker as a template
Could be an idea for a Webasto Logo / Flame symbol ?? the logo would need to be fairly simple
mk1collector wrote:
With the on off switch, I took a switch blank cap and drilled a hole for the light then got a friend who makes stickers to do me a negative of a cruise logo then stuck it on the blank cap and scratched the paint off. Like this.
Post #875356 30th Dec 2020 11:53pm
