Home > Puma (Tdci) > Superpro bushes in front, help needed!
Minch90
All
I have a standard '58 plate 90 with standard shocks, I got the Superpro bushes SPF0075K which are to be used instead of LR part number 552818, took off the front shock, superpro bushes on but there is not enough bolt thread to even engage the lock nut at either end, let alone do it up! Was using the original washers and ensured they are the correct way round.
Am I being stupid and there is a special way of getting this done up? Or are my shocks different? Any help please!! 2.4TDCI 90 - everyday brilliance
S3 V8 Lightweight - in the garage being ignored #newchassistime
S3 lightweight - 2nd car 24V fire risk with a full tilt and the windscreen down
S1 80" - first car fun - 75mph in neutral downhill once #wobblesallround
Post #871620 6th Dec 2020 6:31pm
Jack your axle up so it compresses the damper maybe? QRZ 2e0vpf
Post #871628 6th Dec 2020 6:47pm
Minch90
The problem is the threaded bolts aren't long enough, even on the top turret! 2.4TDCI 90 - everyday brilliance
Post #871636 6th Dec 2020 6:59pm
jst
As above jack it compress the inner bushes slightly to get the nut started.
In the past I have fitted the outer washer then used a pry bar as a lever to compress the washer with the bush under it down and expose thread on the shock to get the nut started. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #871640 6th Dec 2020 7:26pm
Minch90
Sorry being a moron was thinking compress the shock! Thanks Greeni and jst I get what you mean - jack it to compress the bushes Rolling Eyes
Fine plan, will prepare some swear words, get out a pry bar and have another go! 2.4TDCI 90 - everyday brilliance
Post #871641 6th Dec 2020 7:32pm
Wink QRZ 2e0vpf
Post #871642 6th Dec 2020 7:43pm
