Home > Off Topic > Soakaway
walfy
Soakaway
Any builders/groundworkers out that there that can offer some advice
I need to renew my septic drain field.
When the our cottage was extended about a decade ago the builder shall we say wasn't the most diligent. Anyway the drain field is by my reckoning wofully inadequate. We have a bit of seepage through the garden wall onto the public highway, but that could be natural as there is a spring nearby.
Our tank is shared with our next door neighbour, and we've been told by a local builder we need 30m of soakaway pipe per household. Is this correct?
Next issue is what size pipe do I need? Do i just run the same size pipe as the outlet of the tank, I want to split it and have 2 runs of pipework as space isn't there for a 60m single run.
Next question, how deep should the pipe be? We live in a very clay rich soil area.
Ive seen pipe with a felt like wrap, pipe with no wrap and crates. Whats best? 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #871595 6th Dec 2020 5:40pm
jst
the run doesnt have to be a straight line, most are herring bone style. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #871601 6th Dec 2020 5:58pm
walfy
Garden is about 8m wide and from manhole cover to fence is 12m. So not a lot of space to play with.
I think I'm going to be digging up the whole garden at this rate, I have a drive way that sits at the end of the garden but is 1m below garden level with a garage on the far side of that and then the veg patch beyond that.
I have a decent size footprint of land but very narrow 110 D250 SE HT
110 USW SOLD
Post #871606 6th Dec 2020 6:06pm
jst
shame veg patch isint closer!
if driveway is 1m lower your going to be going down that extra 1m in the garden to get below that! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #871614 6th Dec 2020 6:19pm
walfy
but the rules say the pipework should be between 200 + 700mm to aid aerobic breakdown. If I go to deep then this won't happen. But then run the risk od surface water. It's a complete pain in the arse 110 D250 SE HT
110 USW SOLD
Post #871633 6th Dec 2020 6:57pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
The idea of a soak away from a septic tank is for it to percolate through the ground , to many people dig them to deep thinking it’s the same as a soak away from your down pipes , I’ve had my own building company for over 35 years and replaced a few soak aways I can tell you Big Cry , if the cost is shared I would consider a small treatment plant if space is tight and you intend living there for many years Thumbs Up
Stew
Post #871635 6th Dec 2020 6:59pm
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
How do you expect anything to drain/soak into clay? If you have a ditch that has constant flow speak to EA, provided you tank is a twin tank
Post #871662 6th Dec 2020 9:04pm
walfy
This is my issue, I know I have a high clay content but not sure what other options I have without spending huge. I could go treatment plant but the bloke who looked initialy at my issue said they were upwards of £10K, but surely I still have the water problem to deal with? Where does that go? Can it just go to surface and down the drains in the road next to the house?
I have no constant flow water anywhere near us and i have a septic tank that looks like an onion. A big ball with a short vertical section caped with a manhole cover 110 D250 SE HT
110 USW SOLD
Post #871683 6th Dec 2020 9:58pm
JOW240725
I didnt think you could replace cesspits now? I know you cant install new ones, you have to use treatment plants. Soak aways and clay soil dont work well. James
Instagram @suffolk_rovers
Post #871687 6th Dec 2020 10:21pm
Chopperone
You need some professional advice.
We used to have a septic tank with a soak way - same design as yours.
8 years ago we upgraded to a klargester & it was about 6k all in - fitted it ourselves.It will service 35 people.
It services our house & 4 cabins each sleeping 8 people,4 showers,4 loos & 2 kitchens.
There are also tables produced by EA (istr) which tell you how big a unit you require depending on household/type of business etc.
£10 k sounds a bit rich.
I would go to your local supplier of waste treatment plants & explain the problem; klargester through my supplier sent their tech guy to advise.
You may need to do a soak test (google this) basically dig a hole & fill with water and time how long it takes to go away.
The pipe you refer to is covered in a one way permeable membrane known as Terram or Geotech. Buy the white one not the other sort.Also use drainage stone & also cover that with terram.
Just my twopence worth.
Guy May your life be like toilet paper ; long & useful.
Post #871705 6th Dec 2020 11:33pm
AMBxx
The law has either just changed or is due to change shortly. Get some advice regarding that nearby stream as there are much stricter limits regarding nearby water now.
As others have said, it's going to be either a cesspit (cheap to install, expensive to maintain as emptied frequently) or a modern treatment plant (expensive to install, cheaper to maintain as emptied less frequently).
Before you commit to a treatment plant, find out how noisy it is. Ours has an air blower that help the aerobic stuff do it's job. Makes an annoying hum. Now in a soundproof box, but still just about noticeable.
Post #871748 7th Dec 2020 9:49am
stew 46
Post #871751 7th Dec 2020 10:05am
AMBxx
Our installer warned us to keep away from Klargester. He said they used to be great but now use a lot of plastic in the mechanical bits. He was concerned about them wearing out. No idea if others would agree.
He liked Falcon but if we did it again, I'd try and find something without an air pump.
Post #871753 7th Dec 2020 10:16am
stew 46
Was just showing these as an example, certain ones you still need a soak away but reduced by 20% ish
Post #871754 7th Dec 2020 10:19am
Wireworld
United Kingdom 2015 Defender 90 Puma 2.2 SW Aintree Green
We have just had the same issue with our septic tank and the law now requires us to fit a packaged treatment plant. As we have clay subsoil which would never pass a porosity test we had to apply to the EA to drain using a seasonal soak away and ditch. There are permitted rights to drain if you can prove porosity or have a water course, but not if you have neither. I had to make a full EA application.
We also had to make planning and building reg applications.
Post #871769 7th Dec 2020 11:45am
