Home > Maintenance & Modifications > Extended side tank
Page 3 of 3 <123
jst
mine is blanked off.
i worked it out as around 4ish L too
Prior to Tim fitting his he filled it to the outlet and its a great deal more if i remember correctly. certainly enough that you wont run out for the webasto! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #871602 6th Dec 2020 6:00pm
walfy
Is his the same tank as ours? I didn't think it was.
Anyway, I found a brass fitting that fitted the outlet and had a pipe the right dia soldered in and then a 90 deg bend so it faces the correct way and wouldn't snag on anything. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #871609 6th Dec 2020 6:11pm
jst
if i hadnt already fitted my webastos prior to the side tank going in thats what i would of done. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #871612 6th Dec 2020 6:18pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
There’s about 20-25 litres below the height of the filler on Safari Equip arch tank which really does squeeze as much capacity out of the space available as possible if you get the version for 5 seat models without the seat belt bracing brackets. It’s a considerable loss of capacity and range if you don’t connect the balance pipe and I didn’t see the point of adding a 48 litre arch tank and then only being able to use half of it, especially since the extra large main tank already has the balance pipe threading installed.
Some tanks I’ve seen do look much different to the one fitted to mine and extend along the underside of the seat box and may have a much smaller capacity below the main filler pipe, so we might be comparing apples and pears.
I was going to get a proper Pirtek balance pipe made up but never bothered - the standard arrangement worked fine with decent grade hose and makes for easy field repairs, not that I ever had to do any. And if you look at where it is, it’s considerably higher higher up and protected than brake pipes and ABS sensor wiring. I did some fairly extensive googling and could find no evidence of anyone having trouble with damaging that pipe. I covered mine in convoluted tubing to protect it from stone hits but it may also be possible to make a simple guard that utilises the anti-roll-bar fixings. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #871617 6th Dec 2020 6:26pm
nosnibod
Just found a thread with pictures of tanks identical to those I had fitted - about 9 posts down.
https://www.defender2.net/forum/topic3428.html
You can see how much capacity is below the pipe that extends towards the main tank. As an aside you can also see the larger main tank - complete with internal baffles and strengthening.
The whole thread is worth reading until it diverts onto an entirely different type of tank Rolling with laughter Dave
Post #871625 6th Dec 2020 6:45pm
Page 3 of 3 <123
