Home > Puma (Tdci) > Doors removed, no start, is it imobised?!
Moffett
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Dropped the Defender off to a friend of mine who is a panel beater to tidy up the door bottoms. Hinges had failed (all 4, replaced with billet aluminium items now) so the paint had chipped where the doors had hit the chequer plate. Defender won't start, well, it will fire momentarily then quit. I am hoping the issue is the doors are disconnected. He had tried locking /unlocking etc. with the doors off which might have confused the ecu? He reckons it drove into spray booth okay but we just had to push it out. Are the doors the issue do you think? They won't go back on until until Monday as he has also removed the roof to spray. I am however a little worried!
Post #871326 4th Dec 2020 7:25pm
Co1
Could be. Try pushing in the door switches and see if that sorts it.
Post #871327 4th Dec 2020 7:45pm
Moffett
I tried pushing in the drivers door switch, but no difference. I will leave him to it and try again when all the doors are back on. It's the only difference in how it was dropped in really. He hasn't even opened the bonnet. It is funny how it drove into the spray booth though?
Post #871328 4th Dec 2020 7:53pm
A Defender will start with all the doors open, and should start with them removed.
Post #871354 4th Dec 2020 10:08pm
Rashers
For what it's worth, the sales Guy who sold me mine was a Defender driver himself. One of the last things he said to me was if the truck fails to start, blip the door open on the remote, and then try starting it and it should fire up. This will reset the immobiliser.
Now I don't know if that is true, and so far it has never been an issue in nearly six years, but it's worth a try?
He also said that it would come with a full tank of fuel Rolling Eyes
Don't worry, it is probably something really simple.
Post #871355 4th Dec 2020 10:27pm
Moffett
Thanks for the replies folks. Aye, it did drive into the spray both okay signifying that it would indeed run without the doors. I will bring the nanocom and the spare set of keys with me and see what happens.
Post #871369 4th Dec 2020 10:59pm
Moffett
Post #871377 4th Dec 2020 11:13pm
Rashers wrote:
... if the truck fails to start, blip the door open on the remote, and then try starting it and it should fire up. This will reset the immobiliser. ...
This is true, but the doors are incidental, it's the unlock signal from the fob to the 10AS unit that is disarming the active and passive immobilisers. It just happens to unlock the doors (if they're fitted) at the same time.
Post #871381 4th Dec 2020 11:36pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
I went to have a key cut for mine. The guy at timpson put the key in his little box and told me it had no responder in the key, so a new one can be made from a blank. This confused me as i have the ring around the barrel which would tell me otherwise.
Roll on a few months and the ignition was playing up, turned out to be the rear of the barrel where all the gubbins plug into.
I ordered a new barrel and key set and fitted it all.
Car wouldn't start on just the key, ie it was immobilised.
The only way i could get it to start was to include the original key and fob on the same key ring. The orginal key and fob had to be within a few inch's of the ciruclar plastic thing that goes around the barrel.
Have the seperated the key from the fob? Or am i talking Censored Laughing
Post #871382 4th Dec 2020 11:50pm
Moffett
We cycled the key fob lock/unlock more than once. I will try the spare set just in case. What are the outward signs that the immobiliser is not allowing the vehicle to start? I am no longer convinced it is the culprit. It was all I could think of with the door been off was the truck believed it was been stolen!
Post #871383 4th Dec 2020 11:51pm
AndrewS
Does it have central locking? Perhaps the system is confused due to the lack of 'yes im closed and locked' signal going back to the alarm? 130's have feeling's as well you know Smile
Post #871385 5th Dec 2020 12:15am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Sorry for the obvious question-
The interior light hasn’t flattened the battery?
Post #871386 5th Dec 2020 12:17am
Badger110
Turning the key and nothing happens, ie engine doesn't turn.
Post #871387 5th Dec 2020 12:34am
Moffett
NO, she was swinging over like a champion. It will start briefly if left for a few minutes, but does not start on the second attempt. It acted in this manner when I used the spare key after I just got it and realised I had no keyfob with me. I coded a second one with the nanocom and it has never failed to start since. I should mention that the roof is off so the interior lights aren't on. Kevin would not spray the roof in situ as the paint had kind of reacted (original finish) and was peeling off right into the seams. I will have a lovely shiny roof now but not be able to drive anywhere! Next plan is to try the spare key set after it is back together and after that plug in the nanocom and see if I have fuel pressure etc. There were some pre existing faults for the instrument cluster but they are on the ECU since I got it nearly 4 months ago. THey are on the list of jobs after I replace the front UJ. The paint was letting it down in places so when the space came up to have that work done I jumped at the chance. Kind of regretting it now!
Post #871411 5th Dec 2020 11:05am
ickle
Sounds like its immobilised - just a fire and then nothing - red light bottom of left dial lit up as well?
Mines got a combined key & fob from Avon in fact their first prototype one and I get the above if the immobiliser sets itself and I try and start the car. If I press the unlock button, the immobiliser unsets and will start.
Their production keys had the above sorted out.
HTH Keith
Post #871421 5th Dec 2020 1:31pm
